Page 1 of 1
MATERIAL PROBLEM IN MAXIGO 0.8.3
Posted: Fri May 18, 2007 2:54 am
by filippo
I do a simple scene , but Indigo don't render any material...why?
see the image
filippo
Posted: Fri May 18, 2007 3:32 am
by suvakas
Can you upload the scene file please?
[edit] I mean your 3ds max scene file.
I did some test and it works fine here. Strange.
Does anyone else has this problem?
[edit2]
Hey filippo, are those spheres instanced? If yes, then different materials are not supported for instanced models in Maxigo (at least not yet). All instances will have the same material as the parent model had.
Use copies instead.
Posted: Fri May 18, 2007 6:40 am
by filippo
when I turn off the enviroment and I turn on the sun-sky sistem, Indigo "saw" the material..
but I have a incorrect result..
why..?
the scene
http://d.turboupload.com/d/1802736/test_max.rar.html
Posted: Fri May 18, 2007 6:56 am
by Kram1032
lol!
you have an artistic computer!
This way, it looks much less than a test and much more like a pic for the gallery
don't you think?
Posted: Fri May 18, 2007 8:01 am
by suvakas
@filippo
I think it's the polarization that is causing this.
Try to turn off the polarization. If i remember correctly, then it doesn't work in current Indigo versions.
Posted: Fri May 18, 2007 8:27 am
by vansan
More spheres for gallery, cool!
And the signature: "Much more beyond your expectations!"
Posted: Fri May 18, 2007 8:41 am
by Kram1032
oooh! you used polarization!
ok! That's it^^ yup, doesn't work at all.
But funny result, though
Posted: Fri May 18, 2007 1:53 pm
by filippo
the problem was the polarisation.....
thaks to all for help.
filippo
Posted: Sat May 19, 2007 3:26 am
by filippo
final result
Posted: Sat May 19, 2007 4:32 am
by Kram1032
nice, but the buggy polarisation pic was better
