IndigoMax 0.6.4
15 posts • Page 1 of 1
IndigoMax 0.6.4
Post by fused » Sat Jul 01, 2017 4:13 am
IndigoMax-0.6.4-installer.exe: http://downloads.indigorenderer.com/dis ... taller.exe
IndigoMax-0.6.4-RT-installer.exe: http://downloads.indigorenderer.com/dis ... taller.exe
Supported max versions: 2013, 2014, 2015, 2016, 2017, 2018.
Changes:
0.6.4
Updated indigo sdk to 4.0.55.
Fixed OpenCL device selection not being saved.
Changed mat preview tonemapping scale.
Added null material type.
Improved Forest Pack support.
Re: IndigoMax 0.6.4
Post by Oscar J » Sat Jul 01, 2017 6:59 am
8)
Re: IndigoMax 0.6.4
Post by suvakas » Mon Jul 03, 2017 9:36 am
Should it be possible to use IndigoMax as an ActiveShade renderer?
Suv
Re: IndigoMax 0.6.4
Post by Oscar J » Mon Jul 03, 2017 10:54 am
I think yes. It doesn't for you? What Max version are you using?
Re: IndigoMax 0.6.4
Post by suvakas » Tue Jul 04, 2017 9:31 am
Nope, can't assign it as an ActiveShade renderer. Max version 2016 here.
Suv
Re: IndigoMax 0.6.4
Post by Oscar J » Tue Jul 04, 2017 10:03 am
Yeah, saw a bug report about the 2016 version in the bug tracker. Hope they'll resolve it.
Jay-ko
Re: IndigoMax 0.6.4
Post by Jay-ko » Wed Jul 12, 2017 7:31 pm
I need a 3ds Max 2018 version, is it possible to build it?
errare humanum est
Re: IndigoMax 0.6.4
Post by fused » Thu Jul 13, 2017 3:21 am
Updated builds with max 2018.
Jay-ko
Re: IndigoMax 0.6.4
Post by Jay-ko » Thu Jul 13, 2017 3:34 am
Thanks a lot :D :D
errare humanum est
Jay-ko
Re: IndigoMax 0.6.4
Post by Jay-ko » Thu Jul 13, 2017 8:04 pm
About the old scene created with Maxigo.
Is it possible to have a script capable to remove all the instance of the old exporter?
In the best case convert automatically Maxigo materials to IndigoMax materials?
errare humanum est
Jay-ko
Re: IndigoMax 0.6.4
Post by Jay-ko » Wed Aug 09, 2017 3:34 am
Here I think the value is not linked to the value attributed in the igs created.
Then I think that the default value should be 1.
The texture preview in Indigo renderer seem to show something not corresponding to the gamma atributed (especially when you work on Displacement map or Normal map)
Albedo seems to be oversaturated.
Could you check the process under the 3ds Max exporter; then the math used for this gamma value under Indigo renderer to assure that a Normal map or a displacement map use really a Gamma of 1 instead of 2,2?
Re: IndigoMax 0.6.4
Post by Oscar J » Wed Aug 09, 2017 4:31 am
I think Indigo ignores gamma input for normal maps, but you're probably right about displacement. :)
bahamut
Re: IndigoMax 0.6.4
Post by bahamut » Mon Sep 04, 2017 11:38 pm
Hello.
It appears that this is a problem with exporter.
While making scene with normal pflow i cannot export/render many frames at once. All particles dissapear.
If I render/export frame by frame it works well.
http://zahora.eu – portfolio
http://studio.zahora.eu – photos
Re: IndigoMax 0.6.4
Post by fused » Thu Dec 07, 2017 3:43 pm
suvakas wrote:Nope, can't assign it as an ActiveShade renderer. Max version 2016 here.
Suv
Thanks suv, fixed active shade for 2015 and 2016 in next build (0.7).
Re: IndigoMax 0.6.4
Post by suvakas » Wed Dec 13, 2017 2:51 am
fused wrote: Thanks suv, fixed active shade for 2015 and 2016 in next build (0.7).
Awesome :!: Can't wait !! 8)
Suv
