how save image and file.igi(tonemapping file) in the indigo 0.7?
I saw that the exporter save the render whit the name of scene,but not the tonemapping file.
there are one way to save a render without to rename the scene?
there are one way to save a file.igi?
the new exporter is wondefull!!
thaks
excuseme to my poor language
esiste un modo per salvare i rendering e ifile .igi in indigo 0.7?
ho visto che l'exporter salva il render con il nome della scena, ma non il file tonemapping.
si puo salvare il render con un nuovo nome senza rinominare la scena?
si puo salvare il tonemapping?
filippo
how save image in the indigo 0.7?(ver.2)
Re: how save image in the indigo 0.7?(ver.2)
*.igi file is supported in the latest 07 T5 build. The only place you can turn on *.igi is the inifile.txt that is located under indigo_dir/Exported_Fom_Max. You have to put "save_igi" to "true". After that the igi files will go to Exported_From_Max/renders folder.filippo wrote:how save image and file.igi(tonemapping file) in the indigo 0.7?
At the moment you can't use custom image name. Will add that in future.filippo wrote:there are one way to save a render without to rename the scene?
Thank you! I'm glad that it even works outside my workstationfilippo wrote:the new exporter is wondefull!!
thaks
Suvakas
