Page 1 of 1
Indigo is not working with max9
Posted: Fri Feb 09, 2007 11:55 am
by Vancliff
I installed everything according to the tutorials, readme files and videos. put the name of the dir in the inifile but everytime i hit render it export the scene and open the picture viewport and indigo shows an error message:
"indigo.exe has detected a problem and most be closed".
I am using indigo M2I616f with 3dmax9 on athlon xp64 3.2 + 2 gig ram DDR2 on MSI 940 motherboard with n-vidia geforce 7300 pci-express 256 DDR2
Posted: Fri Feb 09, 2007 12:27 pm
by surreal
Are all your objects mesh's? Do they all have an indigo material? and do you have a mesh object with an emiter material?
Posted: Fri Feb 09, 2007 12:55 pm
by Vancliff
incredible that a lack of an emitter makes the error. should be an alert message for that as it is for the camera
Posted: Fri Feb 09, 2007 1:00 pm
by Vancliff
ok solved now but where is the rendering after 1 min and 52 secs I just got a black window?
by OnoSendai
In the most recent versions of Indigo it prints an error msg.
Posted: Fri Feb 09, 2007 1:48 pm
by afecelis
you must use Indigo 0.6 official. The latest Max2Indigo only works with that version. Indigo 0.7 has a completely new material system and xml syntax for which exporters for all major 3d apps used need to be rewritten.
But many have successfully used Max9 and U3dreal's Max2Indigo.
Re: Indigo is not working with max9
Posted: Fri Feb 09, 2007 5:42 pm
by filippo
Vancliff wrote:I installed everything according to the tutorials, readme files and videos. put the name of the dir in the inifile but everytime i hit render it export the scene and open the picture viewport and indigo shows an error message:
indigo 0.6 work very well on max9, if you have the problem, you can post it in this forum..
sorry for my language
indigo gira bene su max9,se hai dei problemi, postali qui..
filippo
Posted: Sat Feb 10, 2007 3:10 am
by Kram1032
Fillipo: You don't have to be sorry: The posts of you, I read are quite correct.
(sorry for OT)
It works now in max9
Posted: Fri Feb 23, 2007 9:36 am
by Vancliff
Is working properly now and is rendering really fast
