I have uninstalled Maxigo and now I get this nastiness each time 3DS Max is started:
Do you have any idea how to get rid of this?
I really tried to remove all Maxigo-related entries from 3DS Max folder structure but this one is persistent!
I appreciate all help!
Rgs,
Maxigo uninstall problem
Re: Maxigo uninstall problem
Hey,
Hmm. How did you uninstall it ? Manually or using uninstaller?
Some files are located under user scripts folder:
C:\Documents and Settings\User\Local Settings\Application Data\Autodesk\3dsMax\MaxVer\enu\scripts
Did you remove those too?
I have uninstalled it using uninstaller and that was confimed with "sucess" message. Then - indeed - I have manually deleted Maxigo folder in 3DS Max (User\AppData) folder as you indicated but this did not help.
Hello,
I've ran at similar problem. If this error occurs on opening file, than it means you need to remove Maxigo Maxscript persistent values from file. The easiest way to accomplish that is to merge all objects from old file to an empty scene.
Unfortunately, persistent values get created for any opened file (while Maxigo is installed) even if you haven't used Maxigo for rendering, so you'll need to go through all ever opened files to wipe Maxigo clean. That's kind of bad programming practice.
Hope it helps,
Hope it helps,
Ups. That's really not a good thing. I didn't know about that problem before.
This kind of behaviour will be gone soon when Maxigo will be a proper plugin.
Hi Subpixel !subpixel wrote:Hello,
I've ran at similar problem. If this error occurs on opening file, than it means you need to remove Maxigo Maxscript persistent values from file. The easiest way to accomplish that is to merge all objects from old file to an empty scene.,
Thank you for this feedback - I've seen your privatemessage but this forum sucks - I was unable to send you a private answer !!!
Actually - you are perfectly right. The reason I used to get these nasty messages was I had a MaxStart file created while Maxigo was installed. And this file must have been contaminated with Maxigo persistent values what caused error message each time Max was started after Maxigo was uninstalled. Now I have created a new MaxStart.max file and it's clear now, though indeed - I get this nasty message for all old files what were created while Maxigo was installed - what a mess
This really looks like a very bad programming practice from Maxigo plugin creators.
Thak you once again !
Well, I have learned this the hard way, as you did, so I'm happy I could be a help.
Anyway, this was one of the reasons I've started developing IndigoMax, which is not yet that advanced as Maxigo, but you might check this out. I would be happy to get some feedback.
Cheers,
Cheers,
It's too bad that it's the first time I hear about this problem.
It would have been fixed long time ago otherwise.
Subpixel, if you knew this, then why didn't you make a post about it?
