This is just a small question/proposition to all the max scripters out there.
Would it be possible to make a script that converts standart max materials to Indigo materials? Nothing fancy. It could convert all the standart mats into Indigo plastic and place the bitmap diffuse and bump textures into right places. It is very time consuming to do it manually.
Would it be possible?
To scripters - standart mat to Indigo
YES this really sucks..
i have a half backed converter...
It converts Standard to indigo ..AND be careful Indigo to KT and vice versa ... so be carefull it will crash when there are indigomaterials
in the scene and no KT ( Kerkythea ) plugin installed..
Simple remove all that has to do with KT in the script to fix it...
Sorry i'm too lazy..
if someone fixes this it would be cool if he could post it here for others.
Never forget we all only got some cause some of us contribute
lagely...
It is not encrypted so feel free to improve it !!
Here it is
cheers
u3dreal
lagely...
Here it is
cheers
u3dreal
- Jakub Jeziorski
I've removed some lines, added some new ones, trying to make the script quasi-inteligent [it should recognize all 5 indigo material types] and added a check box for exporting 3ds data.u3dreal wrote:if someone fixes this it would be cool if he could post it here for others.
lagely...
When I'll find some more time, I'll add more material recognision (raytrace, architectural and Arch&Design)
It seems it's working, but I haven't tested it carefully, so drop me a line if something goes wrong
here's a script
cheers
Jakub
