mirror again
12 posts • Page 1 of 1
losbellos
mirror again
Post by losbellos » Sat Apr 19, 2008 8:50 pm
Hej There,
As I searched throughout the forums this question asked several time.
How to make a mirror material in max.
Without touching the xml files.
Is that possible? (latest maxigo version)
If possible please write me an example parameters.
Somehow I was unable to make it.
Thanks for the help.
Sukrim
Post by Sukrim » Sat Apr 19, 2008 9:01 pm
Hm, you just have to reflect everything... Btw. mirrors IRL have a thin silver film on the back side, so maybe you can use the silver nk-file as well.
Post by suvakas » Sat Apr 19, 2008 9:35 pm
Hey,
Use Non-transparent glass material with high IOR value. Higher IOR = more reflective.
losbellos
Post by losbellos » Sat Apr 19, 2008 9:44 pm
thanks
so simple.
jinj
Post by jinj » Sun Apr 20, 2008 1:24 am
Hi all!
I have a small question.
The diamond nk file want run correct (it's high reflective, non transparent and black), how can I simulate diamond material.
please post an immage of the setted indigo mat for max.
jinj
Sukrim
Post by Sukrim » Sun Apr 20, 2008 1:42 am
According to http://deeppixel.uw.hu/projects/NK_materials.html Diamond works like you described...
I'm not sure, but nk Files seem to describe _only_ the reflection of a material, not the refractive part, so the diamond NK file might be correct but not give you the expected results.
Post by suvakas » Sun Apr 20, 2008 2:17 am
Hey jinj,
You could start with these settings and tweak from there.
It's based on ZomB's material:
http://www.indigorenderer.com/joomla/fo ... ht=diamond
i don't know how physically accurate it is though.
jinj
Post by jinj » Sun Apr 20, 2008 4:03 am
thank's for replyng Suvakas.
I try this setting. I know that ior value for diamond 2,419 is.
in maxwell if you flag ''use full ior'' the ior file can be used to simulate the real material whitout any other setting.
I open whit wordPad the IOR file and the nk data file containing diamond data. so The two files contain exactly the same information, listed in the same mode. So i Think that the exporters translate the two information in two different mode.
Thank's again.
jinj
Post by suvakas » Sun Apr 20, 2008 4:55 am
The thing is, that the transparent NK files are not working in Indigo.
Post by pixie » Sun Apr 20, 2008 9:11 am
Mirror being a perfect reflection should use a specular material, isn't that defined in maxindigo?
smrutibora
Re: mirror again
Post by smrutibora » Thu Apr 25, 2019 11:21 pm
I attempt this setting. I realize that ior esteem for precious stone 2,419 is.
in Maxwell in the event that you banner ''utilize full ior,'' the ior record can be utilized to reproduce the genuine material without some other setting.
I open whit WordPad the IOR document and the ink information record containing jewel information. so The two records contain the very same data, recorded in a similar mode. So I Imagine that the exporters interpret the two data in two diverse modes.
tocnaza
Re: mirror again
Post by tocnaza » Wed May 08, 2019 2:32 am
Thanks for information.
