Page 1 of 1
Error: Failed to load texture
Posted: Fri Jun 26, 2009 8:04 am
by Silmä
Is Indigo supposed to give this kind of error when the texture files are on different disk drives than indigo itself, or am I doing something wrong?
This happened when i installed the latest indigo and blendigo, and tried to re-render one of my older scenes to see the difference in render times. The file paths on blendigo are correct, but somehow it seems to screw them up during export.
Re: Error: Failed to load texture
Posted: Fri Jun 26, 2009 1:04 pm
by benn
Silma: You need to put the textures on the same drive as the scene - i'll add it as a fix for the next version of Blendigo.
Posted: Fri Jun 26, 2009 5:31 pm
by Doug Armand
I'm getting same thing and the image file is in the same drive/folder as the saved blender file.
Error: SceneLoaderExcep: Failed to load texture 'c:\users\dougar~1\appdata\local\temp\..\..\..\..\..\..\..\f:Dougs Stuff\3D\Blender Scenes\Iceberg\waterripple8et.jpg': Error loading texture file 'c:\users\dougar~1\appdata\local\temp\..\..\..\..\..\..\..\f:Dougs Stuff\3D\Blender Scenes\Iceberg\waterripple8et.jpg' - file not found
a work around for the moment is to save the .igs file and then edit it and provide the full path to the image file.
Posted: Fri Jun 26, 2009 6:26 pm
by WytRaven
Doug Armand wrote:a work around for the moment is to save the .igs file and then edit it and provide the full path to the image file.
That's what I have to do with the Mac version at the moment too.
Posted: Fri Jun 26, 2009 6:57 pm
by Doug Armand
Actually I just tried to render an older complex scene and this is a real problem. When you have loads of textures to replace and the blender file is huge it's a mammoth task to replace them all. Needs to be fixed asap.
Posted: Sat Jun 27, 2009 8:54 pm
by Doug Armand
Well two days and no fix?
come on guys this is now commercial software and needs a quick fix for this and soon.
I don't want to have to hand edit every time I render and this is getting real annoying. I'm surprised many others haven't complained about it.
Posted: Sun Jun 28, 2009 12:14 am
by Polinalkrimizei
No batch yet, but having the same problem!
Everything is on the same disk, but I get the same error message!
Posted: Tue Jun 30, 2009 5:22 pm
by Doug Armand
Still waiting for a fix guys - whats the hold up?
Posted: Tue Jun 30, 2009 5:29 pm
by OnoSendai
Hi Doug, we should have a fix for this tomorrow. Sorry about the inconvenience.
Posted: Tue Jun 30, 2009 5:35 pm
by Doug Armand
Thanks for the quick reply Ono - information is always welcome
