Page 1 of 1
help with RGB emitters
Posted: Thu Feb 05, 2009 11:12 am
by souloxide
Hi guys... need a little help with RGB emitters.. It's been quite a while since I last used indigo.. and now with the 1.1.14.. I noticed that the settings for emitters have changed (for a very good reason i suppose).
I have no problems with blackbody emitters... however, RGB emitters seem to be a blur to me. How do I use an RGB emitter for.. let's say... a small glowing orange tint lightbulb?
I tried several settings.. I can't get it to glow.. err emit light.. please help. Thank you.
Posted: Thu Feb 05, 2009 11:47 am
by souloxide
nevermind...
i got it working.. cheers to 1.1.14! awesome stuff!
Posted: Thu Feb 05, 2009 10:55 pm
by Kram1032
orange-tint lightbulb is supposed to be a blackbody, though
Posted: Thu Feb 05, 2009 11:38 pm
by souloxide
I'll take that as a fact. Thank you
Although, I must say I successfully used an RGB emitter to my lightbulb.. it gave me a better result than using the blackbody..
However, now i'm a bit confused.. which type of objects do you apply RGB emitters with? what exactly is it for then?
Posted: Fri Feb 06, 2009 1:57 am
by Kram1032
Lightbulbs basically are nearly-blackbody-lights. Blackbody lights work with heat.
If you want to make a red, blue or green led, RGB would be ideal.
With blackbody lights, you can only cover a certain range of colours. With RGB lights, you can more or less use any colour...
For any heat light source or anything which could be approximated by heat-emission, I'd use blackbody but as soon as you've a different colour (say, green or, uh... pink? ^^) you'll have to use RGB.
A lightbulb has roughly 2700 K (usual household) to 3400 K (studio) as colour temperature...
It emits with 12-15 lm/W
A standard halogene-lamp reaches 25 lm/W at 3000 K, so it's more efficient and the emitted light is better.
Info from Wikipedia....
I hope that helped
Posted: Fri Feb 06, 2009 5:55 am
by souloxide
great info! appreciate it alot! can't wait to give it a try.. Thank you!
Hopefully, this post continues to grow more.. it's amazing how much information one can get just by asking.. appreciate this alot! cheers!
