Why it's always rendering one layer
Why it's always rendering one layer, I don't know what I'm done but I've got about 10 models on 10 layers (from 1 to 10) and it's rendering only what's on layer 2, any ideas?
hmmm well indigo caters for 8 layers numbered 0-7
layer 0 is the default and also for the sun and older material format (prior to emissive materials) so you might try remedying that first - possibly its just indigo interpreting your xml strangely - you do have the layers enabled in the indigo UI?
possibly an exporter issue too...
HTH
HTH
I found solution!
I've got second window with 3D view for layer 2 (changed on uv window later), I just needed to change there layer and now everything is ok :], strange but blendigo was still taking settings from that (un-existed) window
Can I have Nobel Prize ?
Thx
BigFan
Thx
BigFan
