Page 1 of 2
Indigo_export_0.6test5_beta2
Posted: Fri Oct 20, 2006 5:17 am
by leope
Added a button to help camera focus on selected object (eg. an empty)
Distance is from camera (getLocation()) to the axis of the object (getLocation())
I hope it's the right way...
http://mediawiki.blender.org/uploads/d/ ... _beta2.zip
Posted: Fri Oct 20, 2006 5:41 am
by jurasek
works perfect.
Tnx Leope for that.
greetz,
jur
Posted: Fri Oct 20, 2006 9:30 am
by mzungu
Extruded curves don't seem to export presently. Workaround is currently to convert them to meshes. Plans to support them?
Posted: Fri Oct 20, 2006 4:00 pm
by afecelis
Radiance's blender tut says everything in blender must be converted to meshes prior to exporting. Also any modifiers applied must be collapsed
@Leope: this version of the script rocks! Love the new ToneMap type options! Thanks a ton!
Posted: Fri Oct 20, 2006 6:40 pm
by Kojack
I have had troubles with beta 1, but now it works perfectly
big thx,
Raphael
Posted: Fri Oct 20, 2006 7:42 pm
by 8bstudio
Posted: Fri Oct 20, 2006 10:08 pm
by drBouvierLeduc
A request : it would be great to have an option to save the settings, so you don't have to enter them each time you open the exporter.
Posted: Fri Oct 20, 2006 11:06 pm
by tuxman
Hi all, I'm new to indigo, and I have been having a very good time with it.
However this morning I downloaded this exporter(Dev-Indigo_export_0.6test5_beta2.py) and indigo06_test5 but I cannot render anything because the whole scene is black(I don't see nothing at all). I've tried with some different very simple scenes but results were all the same. Probably I miss something, but I'm not able to find it on my own till now.
Any help?
I underline that those scenes work well with indigo0.5_test7 + indigo_export_0.5beta.py
by tuxman
Any help?
ps: sorry for mistakes
Posted: Fri Oct 20, 2006 11:28 pm
by Kojack
@tuxman: Are you sure that you use beta 2? I have the same problem with beta 1, but when i try beta 2 it works.
Posted: Fri Oct 20, 2006 11:47 pm
by tuxman
Yes I Downloaded the file on top of this topic. However I've seen that opening file.py it says:
# INDIGO v0.6 test 5 exporter beta 1
But it's only a comment problem because making a diff between beta2 and beta1 files:
472d471
474,476c473
< file.write("\t\t\t</blackbody>\n")
551a549
> evtFocus = 4
680a679
> d['focusdistance'] = FocusDistance.val
696a696
> FocusDistance.val = rdict['focusdistance']
723a724
> Draw.Button("X", evtFocus, 265, 340, 15, 18, "Get the distance from the selected object")
808a810,820
> if evt == evtFocus:
> global FocusDistance
> currentscene = Scene.GetCurrent()
> camObj = currentscene.getCurrentCamera()
> try:
> selObj = Object.GetSelected()[0]
> loc1 = camObj.getLocation()
> loc2 = selObj.getLocation()
> FocusDistance.val = (((loc1[0]-loc2[0])**2)+((loc1[1]-loc2[1])**2)+((loc1[2]-loc2[2])**2))**0.5
> except:
> print "select an object to focus\n"
810c822,823
> Draw.Redraw()
> update_Registry()
So?
Thanks for any help.
Posted: Sat Oct 21, 2006 12:30 am
by leope
mmm... i don't know...
the only thing i can suppose:
1.if you use linux with not a recent version of wine, indigo 0.6 beta don't seems to work.
2.if you have the last version of wine but you set an output image size too small, then the screen is black with dotted lines.
Try post your scene here (or a light version of you scene).
leope
Posted: Sat Oct 21, 2006 12:38 am
by lego
wouldn't it be better to have focus set as the distance from the 3d cursor?
Posted: Sat Oct 21, 2006 12:42 am
by zuegs
@tuxman:
please check that you use reinhard tonemapping... perhaps new exporter defaults on linear tonemapping that stays black if you don't set correct linear-scale.
greets zuegs
Posted: Sat Oct 21, 2006 2:37 am
by tuxman
I use wine-0.9.8(not the lastest) however I tried indigo-0.6-test5 on windows and black render had followed me
Here some material that could help finding problem:
internal work screen of the simplest scene I could do, one sphere with plane and sunlight:
indigo0.5_test7 rendering:
xml file exported for indigo0.5_test7:
http://www.filehosting.cc/file/10603/te ... d-xml.html
xml file exported for indigo0.6_test5:
http://www.filehosting.cc/file/10604/te ... d-xml.html
differences between two exported files:
@zeug: I'm sorry but I don't know what reinhard tonemapping is about. I've tried changing button from linear to reinhard but render is black again.
Maybe something of reinhard(or linear) default setting is not correct for me(I do not touch scale or pres values because I know nothing about them, maybe that causes black render)
thanks for help.
