Bump map correct in Blender different in Blendigo
4 posts • Page 1 of 1
Russdigo
Post by Russdigo » Fri Apr 18, 2008 3:24 am
I have look round the forums and manuals and pratted around with Blender but no luck.
My bump is right scale in Blender and not right scale in Indigo. When I change the scale or the map repeats in Blender no change happens in Indigo. I can control the bump about with B but not the scale....?
(using v1.0.8 Indigo and Blendigo)
alexmeyer
Post by alexmeyer » Fri Apr 18, 2008 3:44 am
For scale you need to mess around with the UV map itself. I'm assuming you just set the bump map as a texture and left it at that?
You should be able to find some tutorials about Blender UV-mapping somewhere, if you don't know how to already.
Russdigo
Post by Russdigo » Fri Apr 18, 2008 4:36 am
Cheers, direct UV altering seems to work.
HtechB
Post by HtechB » Mon May 12, 2008 1:37 am
Russdigo wrote:Cheers, direct UV altering seems to work.
You mean actually manually tilling the texture?
