Set smooth/Subsurf error?
I've been trying to render this test of some simple glasses and I cannot for the life of me figure out what's wrong. It looks as though "set smooth" is being ignored, although I do have it selected. I've also added a subsurf modifier to level 3.
I thought maybe that I didn't have enough geometry, as the first one I set "spin" to 25. So I tried it again and set spin to 85. More than enough!
What else could it be?? Yes - normals are just dandy.
Using:
Blender 2.45
Indigo 1.09
Blendigo 1.08
Using:
Blender 2.45
Indigo 1.09
Blendigo 1.08
- Errors
- glassError1.jpg (64.79 KiB) Viewed 3807 times
- Close up detail
- glassError2.jpg (11.5 KiB) Viewed 3807 times
- Overnight render
- glassError3.jpg (30.29 KiB) Viewed 3807 times
- Neobloodline
Did you actually select "apply" or did you just set it up and export it... it's kind of confusing but you have to actually apply it from the stack first then export. It can appear like it's applied but really it isn't if you run the exporter. Goto editing--> modifiers --> subsurf --> then make sure you set levels to whatever you want it to be, not just the render levels.. and hit apply. Then export. It's a crappy method and it eats puter juice but it works for me.
Neobloodline, that's just partly right:
The subsurf, being visible in the viewport, also gets rendered. No need to apply it.
But if you want to render it at a higher res than your viewport shows, you need to set your subsurf value to the according value in the very end. As then, your viewport also shows it, you still don't need to apply the modifier
mcm: you shouldn't use autosmoothing in Indigo. It's buggy. If you meant that, yeah 50nIt, check for autosmoothing and turn it off, if you used it.
Apply Scale rot also always is a good idea
And an other possible thing: Try to remove doubles... It could be, that the normals simply are ignored, because there actually are gaps
Ono... I beg to disagree.
Granted, you know more about this stuff than I'll ever hope to know, that's just a given, but I'm not seeing this problem in other renderings. I started this model as a way to reproduce the errors photoguy is getting in his render..
http://www.indigorenderer.com/joomla/fo ... php?t=3839
I didn't reproduce his error, but you can see that his render is not doing what mine is. I also don't see this type of strangeness when looking through any of the Glassware renderings in the Gallery.
I do agree with most of what Kram posted. I know you don't have to apply subsurfing, but I tried it anyway just to see if there was a difference, and there wasn't. I rarely (if ever) use autosmooth as I usually just use an edge split modifier if I need to. As before - I tried both anyway to see if there would be a difference, and there wasn't.
I applied scale and rotation, no difference.
I removed doubles and check normals about 38 times or more. Everything is fine, no difference.
Maybe I'll just post the .blend file and have another pair of eyes look at this, as I'm out of ideas.
hum... you set spin to 25 and 85...
why didn't you simply model the whole thing from a circle?
try to use the cast modifier so that the shape gets *really* round.... That could also be the problem.
Oh, and you'll need to use two cast modifiers, limited to each the inner and the outer wall, per assigning according vertex groups and you'll also need to switch "sphere" to "cylinder"
....Or you simply remodel them from scratch.
- joegiampaoli
5OnIt
It will be almost impossible to recreate the same errors Photoguy had in his scene. Even the slightest difference in thickness and shape of the glass, even on it's base will create a completely new thing, you have to remember you are almost playing with lenses no matter if your IOR's are correct.
hmm, I did not realize that it was buggy. I actually had an identical set of segmented rendering problems with a glass object. I turned on autosmoothing, set a high angle, and they went awayKram1032 wrote:....you shouldn't use autosmoothing in Indigo. It's buggy. If you meant that, yeah 50nIt, check for autosmoothing and turn it off, if you used it. ...
BbB - Thanks but I've already tried that. Started with a Cylinder, no difference. I'm just going to upload the file and let someone else look at it. I've looked at this thing 'till it felt like my eyes were about to bleed and I still don't see anything wrong.BbB wrote:I second Kram. I would model such a simple glass starting with a circle. Anyway, if you could show us a wireframe of your glass in edit mode (i.e. without modifiers), I'm sure that would help finding the source of the problem.
- GOWTestB.blend.zip
- Blend File
- (88.56 KiB) Downloaded 248 times
