Lights not working through glass
7 posts • Page 1 of 1
cheese on toast2
Post by cheese on toast2 » Thu Feb 28, 2008 8:48 am
Hi everybody.
I'm currently working on an Audi R8, some of you may have seen it in the new images upload gallery and I've come across a little problem. some of you may have seen the R8 and noticed that it has little 'fairy lights' under the main headlight. I tried to immitate this by adding emmissive spheres inside the headlights of my model, but when I render it, the lights do not show up from behind the glass. I've had this problem before with a different model and I decided to give up, but this time its annoying me so I wanna know how to fix it lol. does anybody have any idea why this might be happening?
thanks
Post by suvakas » Thu Feb 28, 2008 9:11 pm
Glass one sided maybe?
cheese on toast2
Post by cheese on toast2 » Fri Feb 29, 2008 4:45 am
do you mean that I've only applied the glass material to one side of the headlight? If so, then no, the glass texture is on both sides, and I dont think it could be a normals problem, because I've hit ctrl+n, and I've flipped the normals so many times in lots of different combinations that it couldn't possibly be that. Although, would the fact that the headlight glass is a plane be anything to do with it?
psor
Post by psor » Fri Feb 29, 2008 4:48 am
Yupp, ... it should be a "real" object which means a 'single sided' plane is
no good. So give it some thickness! This should solve your problem. :D ;)
take care
psor
"The sleeper must awaken"
cheese on toast2
Post by cheese on toast2 » Fri Feb 29, 2008 4:53 am
Thanks! :D
jurasek
Post by jurasek » Fri Feb 29, 2008 7:43 am
Works fine here;)
greetz,
jur
cheese on toast2
Post by cheese on toast2 » Sun Mar 02, 2008 5:36 am
*jealous* lol
Users browsing this forum: BLEXBot [Crawler] and 1 guest
