How to apply bump?
cooler_inc
How to apply bump?
Post by cooler_inc » Sun Sep 10, 2006 9:56 pm
Hi, everybody!
If I understood right there is no support of the bump mapping in the Indigo0.62
But maybe there is a way-out? Is it possible to apply bump (or disp) like a modifier?
zuegs
Post by zuegs » Sun Sep 10, 2006 10:06 pm
it's temporaly broken in v6.2... will be back in in v6.3 i suppose.
What type of modifier you think? Post processing?
cooler_inc
Post by cooler_inc » Sun Sep 10, 2006 11:00 pm
Not P.P.
I said "modifier" as an example. I know that this function is broken in v0.62
I would like to render an automobile tire with protector. When I was a 3dsmax user I could do this by using such modifier. So I just want to know is it possible to make a displacement with Blender tools?
Sorry for my English :oops:
zuegs
Post by zuegs » Sun Sep 10, 2006 11:03 pm
ahhhh sorry, :oops: you like to modulate the mesh with the texture before exporting... that sounds good, i never tried myself... perhaps someone in a blender.org forum could help on this.
cooler_inc
Post by cooler_inc » Sun Sep 10, 2006 11:16 pm
cooler_inc
Post by cooler_inc » Mon Sep 11, 2006 6:40 pm
Here is the result of applying bump (I'm not satisfied :evil: )
Be waiting for the next Indigo release.
zuegs
Post by zuegs » Mon Sep 11, 2006 9:41 pm
nice to see that it works... ok, the displacement is a bit hard... i think bumpmapping would also be faster :roll: ... let's wait on v0.6t3 :wink:
8bstudio
Post by 8bstudio » Wed Sep 13, 2006 10:48 pm
How you apply your bump map? Like UV, Orco, or.....
I tried but Indigo console write me always 0.00000 mutation.... and nothing to see!!
This my code:
</material>
<material>
<name>coccio</name>
<diffuse>
<colour>1.000 1.000 1.000</colour>
<albedo_texture>
<uv_set>uv</uv_set>
<path>laterizio01.JPG</path>
<gain>1.000000</gain>
<exponent>2.300000</exponent>
</albedo_texture>
<bump_map>
<uv_set>uv</uv_set>
<path>bubinga.jpg</path>
<gain>1.630178</gain>
<exponent>1.000000</exponent>
</bump_map>
</diffuse>
</material>
zuegs
Post by zuegs » Wed Sep 13, 2006 11:42 pm
Hi 8bstudio,
what lightning you are using in your scene? And which Indigo version and which Exporter version do you use? Check out the Blender Tutorial at
http://www.indigorenderer.com/blender_tut
regards
zuegs
8bstudio
Post by 8bstudio » Thu Sep 14, 2006 12:34 am
Hi Zuegs,
I use sun light and indigo version is 0.61T, eporter is 0.6 beta1. I follow tutorial but....
thanks, bye
zuegs
Post by zuegs » Thu Sep 14, 2006 1:02 am
hi 8bstudio,
i'am not sure if i remember right, i think, bump-mapping was broken in v0.6t1. And v0.6t2 has broken specular-color. All v0.6 versions are for test only... so you could try with indigo v0.5 and the v0.5t7 (highest 0.5) exporter...
zuegs
[EDIT]or was it broken in v0.6t2 :?: At all it's perhaps better to first check it in v0.5 :wink: . At all you should first get some mutations while rendering which seems to be a lightning problem and not a bump-mapping problem :roll:
8bstudio
Post by 8bstudio » Thu Sep 14, 2006 1:17 am
...strange! With 0.5 version and exporter Indigo stop at "doing initial warmup...". If I disable "Nor" button, it starts!
:cry:
zuegs
Post by zuegs » Thu Sep 14, 2006 1:26 am
??? hmmm... image file in the same directory as XML? Have you read the hole console messages (no warnings while indigo startup)? When you disable "NOR", do you then get the "COL" texture correctly?
cooler_inc
Post by cooler_inc » Thu Sep 14, 2006 1:29 am
2 8bstudio: If you want to apply bump read this
http://jmsoler.free.fr/didacticiel/blen ... ing_en.htm
I didn't use the option 'nor' in the material. The wheel you saw is just a mesh that contains over 100.000 poly.
if you're interested I can explain in detail but a bit later, now i'm very busy.
8bstudio
Post by 8bstudio » Thu Sep 14, 2006 1:30 am
Yes!
I try to upload my xml file... If there is someone who want to try with mine... Thanks a lot!!!
http://www.8bstudio.com/bonus/xml.zip
Thanks to Zuegs and Cooler_inc
