Possible? [HELP]
The13Ronin
Possible? [HELP]
Post by The13Ronin » Mon Jun 04, 2007 10:25 pm
Is it possible to use more than one texture at a time? If so how? I want to make a multitextured scene.
SmartDen
Post by SmartDen » Mon Jun 04, 2007 10:31 pm
Do you mean multitextured object?
The13Ronin
Post by The13Ronin » Mon Jun 04, 2007 10:41 pm
SmartDen wrote:Do you mean multitextured object?
No.
Multiple objects, each with a different texture in the one scene. How is this possible?
SmartDen
Post by SmartDen » Mon Jun 04, 2007 10:50 pm
No.
Sure it's possible. Just assign different material with different textures to each object. I don't understand what your problem is?
The13Ronin
Post by The13Ronin » Mon Jun 04, 2007 10:55 pm
SmartDen wrote:
No.
Don't you need to assign the textures in the Albedo broser? You can only assign one texture there?
SmartDen
Post by SmartDen » Mon Jun 04, 2007 10:58 pm
If you use this version of blendigo http://www2.indigorenderer.com/joomla/f ... 2302#22302
it will happen automaticly if you press Conv-Button ;)
The13Ronin
Post by The13Ronin » Tue Jun 05, 2007 1:09 am
SmartDen wrote:If you use this version of blendigo http://www2.indigorenderer.com/joomla/f ... 2302#22302
Can I use more than one texture on a single object in this way?
SmartDen
Post by SmartDen » Tue Jun 05, 2007 1:21 am
No. Indigo don't support it. But if you have some troubles to texture you earth i have a solution for you. use just one texture. if you need it, i have one
zuegs
Post by zuegs » Tue Jun 05, 2007 1:43 am
if you like to superpose textures you can create teo materials with a texture each and then create/use a blend-material that superposes the textured materials.
Or if you like to assign different textures to different faces of an object you can assign multiple materials to a object in blender and then assign the right material to the right face.
i hope this works :wink: :roll: :lol:
The13Ronin
Post by The13Ronin » Tue Jun 05, 2007 1:51 am
The Conv-Button doesn't work for me :cry: . Why not?
It doesn't convert the textures to my indigo or blender. Is there a manual way to set more than one texture for more than one object in a scene? If not please help me to get this conv-button working?
SmartDen
Post by SmartDen » Tue Jun 05, 2007 2:06 am
more than one one texture on one object does not work because indigo supports only one uv-set, AFAIK
The13Ronin
Post by The13Ronin » Tue Jun 05, 2007 2:12 am
No... More than one object in a SCENE with one texture each. How do I do this?
Post by Kram1032 » Tue Jun 05, 2007 2:13 am
Uhm, simply use more than ONE material :P
for every single Material, you have options.
Let every object use an own material, so you can use a different texture.
The13Ronin
Post by The13Ronin » Tue Jun 05, 2007 2:18 am
Kram1032 wrote:Uhm, simply use more than ONE material :P
But I need to set the material/texture in the Albedo browser?
I only have one box and can set one texture?
zuegs
Post by zuegs » Tue Jun 05, 2007 2:36 am
i still say:
i hope this works
