Blendigo 4.2.2
MZ
Blendigo 4.2.2
Post by MZ » Tue Feb 19, 2019 2:53 am
Archive: https://downloads.indigorenderer.com/di ... 982b42.zip
Windows Installer: https://downloads.indigorenderer.com/di ... taller.exe
Should be compatible with Blender 2.78-
Changelog:
4.2.2
* Compatible with latest 2.79 builds
* Autoupdater
* Bugfixes: dupli lights, dupli light/lightlayer, exr export, uid bug, always default background bug, particle motion blur, external material
Manser
Re: Blendigo 4.2.2
Post by Manser » Wed Feb 20, 2019 12:17 pm
Thanks for your reply. I downloaded the folder as you suggested - and again - there is no installer. I've attached a screengrab.
I am still unclear what to do next. The installer is missing. Do you know the path where I install this myself? Thanks.
MZ
Re: Blendigo 4.2.2
Post by MZ » Wed Feb 20, 2019 6:44 pm
Hi, you can just move indigo_exporter folder to addons path, eg. <path to Blender>\2.79\scripts\addons\
More info about Blender path layout: https://docs.blender.org/manual/en/late ... ories.html
Or, you can zip indigo_exporter folder and install it from inside Blender using preferences/Add-ons/Install Add-on from File button.
aleksandera
Re: Blendigo 4.2.2
Post by aleksandera » Thu Feb 21, 2019 3:39 am
Hi! First of all Thank you for developing the blender exporter!
Can you check the attached scene. The camera focus doesn't export correctly.
Focus_Test.rar
(72.31 KiB) Downloaded 37 times
MZ
Re: Blendigo 4.2.2
Post by MZ » Fri Feb 22, 2019 8:31 am
Your problem has been solved in version 4.2.3.
You can use updater under addon preferences to directly update to this version, though if you use OSX, you might need to download it manually.
aleksandera
Re: Blendigo 4.2.2
Post by aleksandera » Fri Feb 22, 2019 11:10 am
Thank you!
samhayes
Re: Blendigo 4.2.2
Post by samhayes » Tue Jun 18, 2019 4:17 pm
Changelog:
4.2.2
* Autoupdater
* Bugfixes: dupli lights, spanish dictionary dupli light/lightlayer, exr export, uid bug, always default background bug, particle motion blur, external material
Just update to version 4.2.3
Re: Blendigo 4.2.2
Post by Headroom » Sat Jul 06, 2019 11:49 pm
Is there a timeline for availability of Blendigo in Blender 2.8 ?
The Blender Beta seem plenty stable for my needs and Will likely move to a Stable release very soon. It would be nice to be able to transition to 2.8.
MZ
Re: Blendigo 4.2.2
Post by MZ » Mon Jul 08, 2019 3:47 am
Hi, works on 2.80 are in progress. You can expect updates soon.
Re: Blendigo 4.2.2
Post by Headroom » Mon Jul 08, 2019 4:19 am
Awesome! Thanks for the update!
Stoffel
Re: Blendigo 4.2.2
Post by Stoffel » Sat Oct 05, 2019 1:25 am
Is 2.80 still the latest update or has there been a newer version since then?
Re: Blendigo 4.2.2
Post by Headroom » Sat Oct 05, 2019 1:45 pm
@Stoffel how hard would it be to check that on Blender.org ?
AshleyW
Re: Blendigo 4.2.2
Post by AshleyW » Thu Nov 14, 2019 12:24 pm
Great, looking forward to 2.80, thanks!
burnin
Re: Blendigo 4.2.2
Post by burnin » Sat Nov 16, 2019 5:39 am
for the time being, 2.80 is the latest... 2.81 is to be released next week
Last time l checked, works w/ both
Re: Blendigo 4.2.2
Post by Headroom » Sat Nov 16, 2019 1:07 pm
I have Blendigo 4.2.2 enabled in the Bender 2.8 preferences, but it does not show up in the available render engine settings. Are you sure this works ?
Edit: Forget that. Found the solution in the "other" thread.
Users browsing this forum: Majestic-12 [Bot] and 2 guests
