glass seemingly not transmitting light
When I export a model from blender to Indigo 0.7t4, the glass appears black and does not transmit any light. Even after transferring the exact settings from the 'ior_test.xml' for the glass medium and material, I still get the same result. This makes no sense to me as it works fine in the test scene. I only have sky light for illumination. Do I need a light source other than the sky? Are there other settings that effect the material/medium settings?
Yes, if the glass material has absorption the scale does matter; if your object is 10x bigger you will have one tenth of the light transmitted through, compared with the smaller object.Are there other settings that effect the material/medium settings?
The thicker the medium, the less light passes through.The doc wrote:absorption_coefficient_spectrum
Controls the rate at which light is absorbed as it passes through the medium.
scattering_coefficient_spectrum also can cause black materials if it is set too high
I ended up going back into my modelling program and exporting with normals export disabled, and now the blend file is correct. With normals all pointing outward, Indigo is rendering the glass as transparent. I think, really, I need to figure out Blender's modelling system so I don't have to go back and forth
Thx for the help.
don't suppose anyone knows of a command in blender to 'recalc normals outside' while in object mode with all objects selected?
Thx for the help.
Any tips on how to scale things in Blender to get them right in Indigo? (i.e. 1 BU = _____ real world units)CTZn wrote:Yes, if the glass material has absorption the scale does matter; if your object is 10x bigger you will have one tenth of the light transmitted through, compared with the smaller object.Are there other settings that effect the material/medium settings?
