Blendigo (for Blender 2.6x) 3.2.10.0
Posted: Tue Apr 10, 2012 2:07 am
3.2.10.0
DOWNLOADS
ALL PLATFORMS: http://www.indigorenderer.com/dist/expo ... 2.10.0.zip
WINDOWS INSTALLER: http://www.indigorenderer.com/dist/expo ... taller.exe
NOTE: This exporter REQUIRES Blender version 2.62
Changes in this release:
* Correctly check for valid lighting when the only emitters are object particles
* Add exponent to emission scale value and make val/exp property labels consistent
* Allow per-instance materials by re-writing mesh names with material slot names
* remove mn_cubic splat filter radius
* Update indigo install path and output path to suit local machine when loading blend files from other machines
* Fix exporting igmeshes when a material slot is assigned and not used
* Fix model export in quat rotation mode
* Resolved issue with non-uniform scaling and rotation/scale matrix manipulation
* make default render mode plain bidir; add new bidir+mlt preset
* change default sky model to captured-simulation
* remove sharp filter from splat choices; sharp not designed for splatting
MANUAL INSTALLATION
Unzip the archive. Move the extracted indigo folder into your Blender addons folder.
You should end up with <blender scripts>/addons/indigo/
Run Blender 2.6, go into User Preferences/Addons, and find the Render section. Locate the Blendigo entry
and enable the addon by clicking the little checkbox on the right.
INSTALLATION VIA BLENDER
Run Blender 2.6, go into User Preferences/Addons. Click the "Install Addon" button and choose the blendigo-2.5-3.2.10.0.zip file. The addon will be installed and shown to you, ready for activation.
If you are upgrading, be sure to choose the "Overwrite" option when selecting the .zip file.
You can easily check the installed version in the Addons panel. After upgrading/replacing I would strongly recommend restarting blender.
HINTS
Save your User Settings now to make Blendigo activate every time you start Blender 2.6.
Non-windows users will have to also fill in the "Path to Indigo" setting in the "Indigo Render Engine Settings"
panel. (Windows does this automatically from the information provided by the installer). Note that you should
specify the installation directory (or Indigo.app on OSX) for this setting.
YOUR FEEDBACK IS ALWAYS APPRECIATED
As with the current efforts to get Indigo 3.x as complete and user-friendly as possible,
please please keep reporting any issues you find with Blendigo - it is your feedback as
users and artists alone that push Blendigo forward into being the software that works for you.
DOWNLOADS
MANUAL INSTALLATION
HINTS
