Hello,
I stopped using Indigo when it went commercial but now i downloaded the trial because I´m thinking of buying a license.
I played around with it and after 2minutes i ran into my first error. The scene is a simple Cube with an UV-Texture. After exporting i get the Following error:
"A problem occurred with the scene:
Error while building scene: Error while loading diffuse material 'Material': Failed to load texture 'c:\users\user\appdata\local\temp\../../Pictures/Texturen/Seamless/metal/bareMetal_1_diff.jpg': FindFirstFile() failed: 3.
Indigo version: Indigo Renderer v3.0.14, Windows 64-bit build.
Exporter:
Platform:
Author:
Description:
Date created:
Please contact support@indigorenderer.com if you have any questions."
The texture and the scene are on the same disk.
can someone help me? I want a good renderer but dont want to pay for Beta software
Indigo fails to load texture
- ninopiamonte
Re: Indigo fails to load texture
... some betas occur problems
I would suggest you upgrade to Indigo 3.2.3 and Blender 2.61 + Blendigo 3.2.3.1.
Lots of things like texture path checks have been changed and fixed since 3.0.14
It worked, thanks guys for your input
