Heterogeneous participating media tests
Post by OnoSendai » Sun Nov 01, 2009 8:20 pm
So, I've been upgrading the absorption_coefficient_spectrum and scattering_coefficient_spectrum parameters in media to 'proper' parameters, called 'volume parameters'. These can either be constant, (with respect to position), or shaders. In the case of shaders, the shader program can compute more-or-less arbitrary spectra as a function of position.
Here are some tests using a shader to drive the absorption coefficient: (scattering coefficient is zero, so no scattering). There's a cube with IOR 1.0 in the middle of this scene.
Please excuse the noisy renders, I'm working on an old laptop.
Clamped sin wave absorption with phase increasing to the right:
<absorption_coefficient>
        <shader>
          <shader>
            <![CDATA[
def eval(vec3 pos) vec3 :
	vec3(
                sin(
                  doti(pos) * 10.0
          </shader>
          <wavelength_dependent>false</wavelength_dependent>
        </shader>
Colourful absorption test:
        <shader>
          <shader>
            <![CDATA[
							vec3(
                  doti(pos) + 1.0,
                  0.0, #doti(pos) + 1.0,
                  1.0 - doti(pos)
          </shader>
          <wavelength_dependent>true</wavelength_dependent>
        </shader>
       </absorption_coefficient>
WytRaven
Re: Heterogeneous participating media tests
Post by WytRaven » Sun Nov 01, 2009 9:58 pm
Oooooh! Nice! :)
Post by CTZn » Mon Nov 02, 2009 3:54 am
Aaaah yeees !!!
Even though the two examples are only of technical interest there's much more beneath... I can see clouds layers on the first one, and ground fog in the second, yummy
Thanks a lot Ono, how exciting !
Post by Borgleader » Mon Nov 02, 2009 4:14 am
I have a little question about this...would it allow something like, a drop of blood in water? (kind of a gore example but, first thing that came to mind after watching the "SAW" game review)
Post by OnoSendai » Mon Nov 02, 2009 9:22 am
Borgleader wrote:I have a little question about this...would it allow something like, a drop of blood in water? (kind of a gore example but, first thing that came to mind after watching the "SAW" game review)
Sure.. if you can write the shader for it :)
Post by Borgleader » Mon Nov 02, 2009 9:29 am
We will assimilate someone to do it for us 8) No but seriously cool stuff :)
sweetcement
Post by sweetcement » Fri Nov 06, 2009 11:25 pm
Smoke, clouds, etc. Explosions. Air pollution.
I remember the cloudy sky tests a couple of years ago -- used a noise to simulate clouds, looked pretty good.
What would be really interesting is if we could manipulate index of refraction by position...atmospheric media to simulate the sun getting squashed looking during sunset, etc.
Or an atmospheric gradient that is steeper, so it makes the horizon curve up, like some estimates said would be seen by space probes that landed on Venus.
Or mirages, or simulating the horizon on a flat earth, or a world much larger than earth -- atmospheric refraction would make it look like the world was a shallow bowl, since the rays of light near the horizon would follow curved paths because of atmospheric density gradients.
Post by OnoSendai » Sat Nov 07, 2009 11:23 am
sweetcement wrote:Smoke, clouds, etc. Explosions. Air pollution.
I don't think I'll allow modification of the IOR anytime soon, because it makes the ray paths non-linear as you said. Although it would allow some cool effects I guess :)
psor
Post by psor » Sat Nov 07, 2009 11:30 am
OnoSendai wrote:I don't think I'll allow modification of the IOR anytime soon, because it makes the ray paths non-linear as you said. Although it would allow some cool effects I guess :)
What would happen then? :twisted: :wink:
take care
psor
"The sleeper must awaken"
Post by OnoSendai » Sat Nov 07, 2009 11:52 am
If you allow modification of the IOR, you can simulate stuff like heat haze, mirages etc..
benn
Post by benn » Sat Nov 07, 2009 11:55 am
Could we also hack up relativistic effects with that? ;D Bendy stick renders!
psor
Post by psor » Sat Nov 07, 2009 11:57 am
@Nik
Well that's what sweetcement said, then you said ...
... and then I said ...
psor wrote: What would happen then?
More to read as why wouldn't you wanna allow that. Is there a side effect you want to avoid? :? ;)
take care
psor
Post by lycium » Sat Nov 07, 2009 8:39 pm
benn wrote:Could we also hack up relativistic effects with that? ;D Bendy stick renders!
actually, i'm just busy learning about that this evening...
Post by neo0. » Sun Nov 08, 2009 3:07 pm
Will this only be available to people who know ISL?
Post by lycium » Sun Nov 08, 2009 3:19 pm
edit: see nick's reply on next page
