Why should i buy an Indigo License ? serious question...
Re: Why should i buy an Indigo License ? serious question...
Renderer params are :
Pathtrace with bidirectional on
max num of consec rejections (???) : 1000
super sample factor : 2
bvh threshold : 500 000
now i set supersampling to 1 and test again
Your sun and camera settings seem to be different between the 2 renderers. Try to mach those as well.
Okay. You know, I told that about supersampling to illustrate a generic idea.
Maybe suvakas could share his 3dsMax scene with you ? You will then have more elements for a beginning.
Ah, here comes suv
Ah, here comes suv
here are IGI, last benchpicture and MXS files :
http://rapidshare.com/files/269855976/MXvsIG.rar.html
enjoy !
enjoy !
I can't : Maxwell uses UP as "north" and daytime settings for the sun... no one light is used for Maxwell : only emitters and the sun system...suvakas wrote:Your sun and camera settings seem to be different between the 2 renderers. Try to mach those as well.
about the camera : i put the same settings, but the Indigo render is too bright so i have to lower the ISO
Now it is a lot possible that my (default) params for rendering are not the good ones regardless of that scene...
a bit with Vray : the default settings are not the fastest ones...
help me setting the scene and i'll rerender...
Be sure i'm not here to proove Maxwell against Indigo, but as the title says, i just want to make a choice... a good one... and not only because you are nice guys and "full-life-time" license... i need to produce so quality and speed are big parts !
You can use the same daylight system for both of the engines.naxos wrote:I can't : Maxwell uses UP as "north" and daytime settings for the sun... no one light is used for Maxwell : only emitters and the sun system...suvakas wrote:Your sun and camera settings seem to be different between the 2 renderers. Try to mach those as well.
Same camera settings seem to work Ok here. A scale issue maybe?
Your attitude is right, there is no possible confusion naxosnaxos wrote:Be sure i'm not here to proove Maxwell against Indigo, but as the title says, i just want to make a choice... a good one... and not only because you are nice guys and "full-life-time" license... i need to produce so quality and speed are big parts !
I bet everyone here is interested by results, not chit-chat.
I was curious and I made a similar scene.
Here's the result:
Indigo vs Maxwell - Sun-sky scene
Same sun and same camera parameters.
Seems like Maxwell cleans faster in sun/sky situation...
Here's the result:
when i can find time i'll test with a complex scene... again with standard shaders only (more because i can't manage materials well to have the same in both renderers...)
Ok here are my points.
1.
Indigo was the first unbiased rendering engine which introduced Camera Tone Mapping
(CRT is nowadays announced in the Fryrender forum like an revolution )
2.
Indigo is the only Engine, which can import real measured color and emitter data ("tabulated spectrum"); would be nice if this data could be imported in every color channel (albeldo and etc...)
3.
In Indigo you have the opportunity to choose from 4 Sampling methods (bidirectional pt, pt, Bidir-MLT, MLT or to mix with hybrid)
4.
The Material system is complete and universal + dont forget ISl shading .
5.
No long waitings for product announcements (unlike maxwell ).
Ono has lot of secret faeture presents in every snapshot in Indigo releases.
1.
2.
3.
4.
5.
afaik this is already possible!tungee wrote:Indigo is the only Engine, which can import real measured color and emitter data ("tabulated spectrum"); would be nice if this data could be imported in every color channel (albeldo and etc...)
In which renderer is it possible???
I mean for Indigo you can also use tabulated spectrum data for every color based parameter, like albedo etc. But the exporter needs to support this...
ZomB wrote:... tabulated spectrum data for every color based parameter, like albedo etc. ...
That IS exactly what usual artists don't want to read
Users browsing this forum: No registered users and 121 guests
