Some help installing Indigo 64 bit Linux
Hello,
Could I get some help/info on installing Indigo on Linux. We have a dual opteron server that I would like to have run our renderings...currently smp 64 bit Debian Etch.
I have downloaded the latest stable 64 bit tar, but I don't see any make files, etc. What is the procedure for installing/running on linux? Does it still require wine?
Any help would be wonderfully appreciated.
- PureSpider
Re:
Linux newbie here.
When I try to run indigo on a Linux machine I get the message:
I understand I need to do something like: sudo apt-get install libwxgtk2.8-0 to get indigo runing. The problem is I don't have a root account on the Linux machine I'd like to run indigo on, and so I can't install libwxgtk2.8-0 directly. Is their some other way I can get indigo running without using apt-get?error while loading shared libraries: libwx_gtk2u_richtext-2.8.so.0: cannot open shared object file: No such file or directory
- PureSpider
Re: Some help installing Indigo 64 bit Linux
Thanks for the reply
I've been looking at this a bit more, and it seems some librarys can be installed without root. For example: http://winter.eecs.umich.edu/soarwiki/D ... ermissions
The important point seems to be modifying the LD_LIBRARY_PATH and LD_RUN_PATH variables. Can someone who knows about this stuff have a quick look? Cheers.
- PureSpider
So do you think it will be possible to install libwxgtk2.8-0 without root and get indigo running?
