Im trying to accurately recreate these bullets.
I used cu.nk for the top part and it looks fantastic. Im stuck on the bottom part though. I used the brass mat fromthe db and it's just not reflective enough and its a bit too much on the yellow side... Not metallic enough.
[question] WHich mat would you use for this?
- PureSpider
That's the environment of the scene, reflected
There is one basic physical rule wich it is important to know, wich says that if a material reflects 80% of the light it receives, then one can't see more than 20% of it's diffuse component, because
Your metals look perfect to meIn physics, the law of conservation of energy states that the total amount of energy in an isolated system remains constant.
Users browsing this forum: No registered users and 46 guests
