IGS Navigator
IGS Navigator
Hi everyone, i wrote a little tool which helps one to navigate quickly through an IGS-File and edit it. Please report bugs etc. and tell me if you find it useful
Thx
Onfame
Edit:
0.3:
- changed the tab order
- window is now sizeable
- you can send files to indigo now
- improved code/performance a little bit
- materials are now found correctly
0.2.1
- Don´t crashes when File\Quit
- Tabs work now correctly
Thx
Onfame
Edit:
0.3:
0.2.1
- IGSNavigator.rar
- IGS Navigator 0.3
- (229.05 KiB) Downloaded 190 times
- Borgleader
Well, I managed to crash it (looks like german error text that says cannot access memory at address) by choosing File->Quit
When I opened an IGS, it took a while to update the window - in the mean time, it looks like it froze - perhaps you can add a progress bar?
The window doesn't seem to respect its size such that even when maximized there is a scroll bar horizontally.
When the IGS loaded, the materials tab worked as I guessed it would, however when i chose one of the other tabs, I just got "load a file first" - the file is already loaded. Then when I clicked back on Materials, which had worked, it said the same thing
Being able to get to the good parts of the igs is a useful idea, I look forward to where you go with this. What is your programming environment?
- Borgleader
Hmm, I don't know why but ... I tried to load an IGS and it wasn't done after 3 min...so i closed it (wasnt responding).
Oh and being able to see all the tabs would be fun
And it doesnt quite scale correctly
- PureSpider
