tony
by Kram1032 » Wed Jul 16, 2008 7:24 am
AFAIK, you don't need a blend at all...
Just use a glossy transparent material and add your texture as an exponent map...
by OnoSendai » Wed Jul 16, 2008 7:29 am
Yes, Kram has the best way. But exponent mapping on glossy transparent won't be supported until the next Indigo release.
by Kram1032 » Wed Jul 16, 2008 7:37 am
Oh, ok^^
Then, until the next release (thx alot Ono, btw^^), try blending two glossy transparents with different exponents....
Oh and btw - just noticed now, kinda...
Can't see your third pic for some reason
Just me?
tony
by tony » Wed Jul 16, 2008 7:52 am
OnoSendai: Version 1.1.5 or later?
Kram1032: I'll continue testing as you've specified.
Thanks to two.
by Kram1032 » Wed Jul 16, 2008 7:55 am
1.1.5 already is out, so later
tony
by tony » Wed Jul 16, 2008 8:19 am
Excuseme Kram1032, but the glossy transparents material has not Albedo texture, only Bump Map. Where I put the texture?
by Kram1032 » Wed Jul 16, 2008 8:24 am
Oh, sorry...
use your texture as blend map between two glossy transparent. One with a very high exponent (the one where you see through) and one with very low exponent (the one where you don't see through)
Alternatively, you can replace the high-exponent-glossy-transparent with a specular...
cpfresh
by cpfresh » Wed Jul 16, 2008 8:26 am
this looks alot like the tests done with sandblasted glass
by Borgleader » Wed Jul 16, 2008 10:46 am
Yeah they do. that first test looks good though
by CTZn » Wed Jul 16, 2008 1:17 pm
Yep tony, for previews jpg is prefered, thx !
by neo0. » Wed Jul 16, 2008 1:49 pm
Kram1032 wrote:Oh, sorry...
WHat do you mean by between? In the blend material, you can only select two textures.
by Borgleader » Wed Jul 16, 2008 1:55 pm
unless you use a blend which has for textures a phong and a blend....for example...you can get as many textures as you want to ....
by neo0. » Wed Jul 16, 2008 2:13 pm
I tried using a clip map for a glossy transparent but nothign shows up. My image is pure black text on a white background.
A blend map within a blendmap? Heh, i didnt even know you could do that. I'll give it a look. thanks.
by BbB » Wed Jul 16, 2008 7:47 pm
What do you make of this one?
(sorry for the crap render, but it's still cooking. Will update later if it turns out well).
- Frosted.jpg (117.55 KiB) Viewed 4345 times
Users browsing this forum: No registered users and 81 guests
