HELP! Cant get no DOF :(
- kikeonline
Hi guys,
Let me introduce myself, I'm Kike, Architect from Nicaragua, I work with graphics desigh, interior desigh and envoirmental or green house.
I'm a noob in Indigo render , but I see a lot of you guys are pros which makes me feel that I'm with masters that can tutor me.
Ok well my problem is that no matter what I try I CANT GET NO DOF.
I ran the dof_test.igs scene from indigo and it works fine.
can someone send me a blend file with DOF so I can see the parameters?
Or can someone explain me with details how it works? (I did not find any tutorials on DOF)
waiting anxiously for your enlighment indigo masters
- PureSpider
Hi Kike,
You sure got yourself a weird nickname there. Anyway, the thing to remember with Indigo is that it works exactly like an SLR camera does. Which means it won't give you shallow DOF in situations where a normal camera wouldn't.
As a rule, for shallow DOF (which I assume is what you want), you need one or several of these conditions:
1) Large aperture (Anything between 1 and 6)
2) Long lens. A wide angle (like 28mm, or even 50mm) won't give you much DOF. Whereas a really long lens like 120 or so will give you plenty.
3) Small-scale scene. Remember that scale is hugely important in Indigo. If you shoot a picture of a city skyline, even with an aperture of 1, you won't see blurry buildings at the back and front of your focus point. But if you shoot little shot glasses on a table, you will. Somehow you need to make sure that in your applications, you are working with the right scale units.
That's why there is generally not much DOF in Archviz images, unless you're dealing with very small details. Artificially boosting DOF in Arhviz image will make your buildings look like scale models.
So check all these elements and it should work.
- kikeonline
(My nickname is short for Enrique in spanish , somebody told me that is also a slang name for jewish people, but that is not my intentiones at all)
anyeways
This is a test....
I got blur in the foreground for the first time!!! Thanks a lot!!!
How do I control the Aperture? I'm using Blendigo 1.0.9
this are my setting for that render:
Film ISO : 100
Exposure: 1/125
F-stop: 1.4
White Bal: E
Focus Dist: 14.46
Physical Sun
I will continue to do more tests , with a smaller scale.
thaks a lot!
anyeways
This is a test....
Film ISO : 100
Exposure: 1/125
F-stop: 1.4
White Bal: E
Focus Dist: 14.46
Physical Sun
thaks a lot!
- kikeonline
if you aim for DoF, that's ALWAYS the best you can get
If you don't aim for it, it's the worst.
Don't forget, as mentioned above:
DoF depends on:
- distance from the camera to the object you're rendering (closer/more zoomed -> more DoF
- aperture size (or F-stop) (lower f-stop / bigger aperture -> more DoF)
- lens width (more mm -> more DoF)
DoF depends on:
- kikeonline
- PureSpider
- kikeonline
