network rendering central control program (C#)
nikolatesla20
Post by nikolatesla20 » Wed Apr 23, 2008 5:14 am
It's strange because Mono says it supports that property on sockets.
what version mono you trying to use again?
-niko
Post by PureSpider » Wed Apr 23, 2008 5:31 am
I'm using this:
purespider:/home/spider/indigo# mono --version
Mono JIT compiler version 1.2.2.1, (C) 2002-2006 Novell, Inc and Contributors. www.mono-project.com
        TLS:           normal
        GC:            Included Boehm (with typed GC)
        SIGSEGV:       normal
        Disabled:      none
nikolatesla20
Post by nikolatesla20 » Thu Apr 24, 2008 1:58 am
I updated the post and put the source code and binaries zip file on the first page so it's easier to find.
I haven't gotten anywhere with Mono myself yet either unfortunately. Does Indigo run under Linux now?
-niko
dougal2
Post by dougal2 » Thu Apr 24, 2008 2:18 am
There are linux binaries for indigo 1.0.9
nikolatesla20
Post by nikolatesla20 » Thu Apr 24, 2008 2:39 am
Even when I run it under the mono wrapper in windows, it exits when I click the "Load Clients" button, but I probably would have to compile it with mono under windows, but I don't know how to compile it as a solution, they only give examples compiling *.cs files, but I need to be able to include dependencies, etc. Need to read the docs for mono compiling.
-niko
kingcrimson1969
renderman support
Post by kingcrimson1969 » Fri Apr 25, 2008 12:02 pm
hi I was wondering if it's posible to use this program renderman based renderers or mentalray or vray.
could someone here gave sugestions for the support of mentalray or renderman with this awsome queue manager
cheer,
james
Sukrim
Post by Sukrim » Fri Apr 25, 2008 8:05 pm
There are several render managers out there (free ones too) that can handle renderman + mentalray just fine.
This one is just for Indigo (and doesn't have a queue manager I fear).
kingcrimson1969
yeah but this program should also support other renderers
Post by kingcrimson1969 » Sat Apr 26, 2008 1:01 am
Sukrim wrote:There are several render managers out there (free ones too) that can handle renderman + mentalray just fine.
though the bittorrent style tracker is a really good idea and I can tell
you people would use this program if it had renderman or mentalray
support , I would just like to know what file or line in the c# source must I
edit for this to work.
cheers ,
james
Post by PureSpider » Sat Apr 26, 2008 1:12 am
@nikolatesla20: What about rewriting the tracker in PHP with MySQL support?
That way it would run on both linux and windows
dougal2
Post by dougal2 » Sat Apr 26, 2008 2:59 am
Probably Java would be a better choice.
Trying to run a PHP script as a daemon is less than ideal.
kingcrimson1969
Post by kingcrimson1969 » Sat Apr 26, 2008 3:31 am
yeah but how do I add renderman support
or perhaps for lux render :
http://www.luxrender.net/
personally I think this tracker based render manager should have
support for various renderers such as renderman mental-ray and others
or just use pointers to link the manager to the renderer excuetable
for instance
[SETTINGS]
Tracker=10.209.76.61
aqsisPath=C:\Aqsis\bin\aqsis.exe
though would that work properly or would it require some more editing to the source code.
cheers ,
james
Post by PureSpider » Sat Apr 26, 2008 4:38 am
It would definitely need a lot more editing cause the renderer is made especially for indigo and not for *any* renderer ;)
eman7613
Post by eman7613 » Sat Apr 26, 2008 4:55 am
kingcrimson, its not like firefox, there are no extensions or plug ins. if you want it to work for something else you got to program it yourself.
Yes i know, my spelling sucks
nikolatesla20
Post by nikolatesla20 » Sat Apr 26, 2008 6:09 am
PureSpider wrote:@nikolatesla20: What about rewriting the tracker in PHP with MySQL support?
Actually a tracker could be written in PHP and SQL, but it's just that then you need a webserver and SQL database, so it does add some overhead. The main reason I made it this way for starters is to get something going for usage on a local network. I don't think internet rendering, at this time, is really going to be feasible with Indigo, since it doesn't even compress the frame data when it uploads it to the master. There may be a way to optimize that, but I haven't thought of it yet :P and I'm not and indigo render god either lol in that I know all of indigo's options.
Sukrim: could you explain to me what you mean by a render queue? It may be something that could be added if I knew what the needs were. Thanks.
kingcrimson: At this time I didn't write it with a ton of flexibility in mind, only for the current needs that I had. While a plugin architecture can certainly be added, it really is not suited for this purpose yet. But I appreciate the feedback.
-niko
Post by OnoSendai » Sat Apr 26, 2008 6:14 am
A render queue is usually for queuing up different frames for an animation, and going through and rendering them.
It's not super-important for Indigo 'cause stills are more common than animations.
Users browsing this forum: Majestic-12 [Bot] and 4 guests
