How to run indigo from linux bootable CD
Hi all,
well since i have another XP 2000+ standing around but unfortunatelly
no harddisk i was wondering whether it would be possible to run
indigo as a slave under wine from a bootlable linux distrbution like
knopix ... So if anyone has an idea help would be greatly
apprechiated as i don't have many expirince with linux and again less
with wine .. and bootlable linux CDs...
cheers
u3dreal
cheers
u3dreal
- cooler_inc
First of all you must have HDD, copy Indigo zip file and extract it on hdd. After booting your Knoppix mount partition that contains your Indigo. In the command line navigate to indigo folder and type "wine indigo.exe your_file.xml"
Oh, I didn't see that you don't have HDD, try to use Flash-drive or diskette instead hdd.
mstick will be good:>
Slax - Kill Bill version has Wine (but propalby not 0.9.20 so u cant run 0.6tx Indigo)
http://www.slax.org/download.php
greetz,
jur.
greetz,
jur.
Hi all,
thanks again for the comments.... i downloaded knoppix 5.0.1
which has wine 0.9.12 .. and it boots up like nothing
i'm very impressed.....
indigo (0.6test2) runs also just normal as on windows... same commandwindow... same messages ...
but the framebuffer remains black or has some strange
colors but no rendered pic.... also the saved png and exr are "black"
Anyone has had this problem ??? Any suggestions... maybe i try with older version first... do i need wine 9.2 for test6x
that would be a pitty ...
cheers
u3dreal
cheers
u3dreal
How to do that ???eman7613 wrote:you shouldent need to update if it works, if you have problems you can give wine the dll file and it will use it to try and run it more acuratly.
Now have slax kill bill with wine 0.9.21 module and i get
0.9.21 when using wine --version.... so how can i gibe the dll to
wine ??
help would be greatly apprechiated as i think i'm pretty close ...
but same as before indigo renders black image .... ;(
Jurasek can you plz post your setup... so i can get an idea what's wrong ..
cheers
u3dreal
i was getting a black redner when i first try to get it to run, i dont know enouh about indego to know whether it is indego or wine. try the xml file on a windows computer first, if it runs fine on that then move it over to linux, ill try to take some screenshots to so you how but first i gota get my cd burner to work .
also if you need help, www.google.com/linux linux only searches should help ya ;p
Yes i know, my spelling sucks
yes mine does, for some reason even though i provided the corect path for the textures, indigo did not like me using premade textures taht i downloaded or that came with the software (im using Cinema 4d 9.603). Try re making all the textures your using yourself, that worked for me.
