zuegs
by zuegs » Wed Aug 01, 2007 11:06 pm
Hello indigos...
can someone explain me why following material isn't completely transparent for light? When i have a sunlight or meshlight shineing through this material only a part of the light energie arrives on floor.
I thought, that a ior=1 or ior=1.001 should not reflect light and all light should enter inside the material and as material doesn't absorb it should also leave the material at the otherside without any loss???
<medium>
<name>glass</name>
<precedence>10</precedence>
<basic>
<ior>1</ior>
<uniform><value>0</value></uniform>
</basic>
</medium>
<material>
<name>glass</name>
<specular>
<internal_medium_name>glass</internal_medium_name>
</specular>
</material>
by OnoSendai » Wed Aug 01, 2007 11:41 pm
Hi Zuegs.
It should be totally transparent.
Try latest version of Indigo (0.9 test 3).
And post some pics as well perhaps
SmartDen
by SmartDen » Wed Aug 01, 2007 11:55 pm
Hmm... what is totally transparent object good for?
by OnoSendai » Wed Aug 01, 2007 11:57 pm
It's good for testing.. that's about it
zuegs
by zuegs » Thu Aug 02, 2007 10:54 pm
Hi Nick, hi SmartDen,
it's for testing, right
and so I tested a bit arround and found that the effect happens by "MLT+BiDir" when "Max_num_consec_rejects" is low.
Funny is that when using "MLT only" the specular material renders fully transparent already with a very low "max_num_consec_rejects" like 5. But "MLT with BiDir" need a minimum "max_num_consec_rejects" of about 50 to get mostly fully transparent.
Why "MLT" with "BiDir" needs such high "max_num_consec_rejects" to cross one simple specular transparent cube
by OnoSendai » Thu Aug 02, 2007 11:00 pm
Hi Zeugs.
when you set Max_num_consec_rejects low, the resulting calculations are actually biased. (Technically any finite Max_num_consec_rejects leads to biasing)
Bidir can need Max_num_consec_rejects quite high to render a transparent cube, because some sampling paths are quite difficult to sample (low sampling density).
zuegs
by zuegs » Thu Aug 02, 2007 11:37 pm
by Kram1032 » Tue Aug 07, 2007 9:26 am
...and is it possible, to make that value "infinite"?
CoolColJ
by CoolColJ » Tue Aug 07, 2007 10:15 am
I just set mine to 3000 and leave it there
The shadow areas get much darker with it set high in some tests I did, looks nicer. Put it at 1 and everything is very washed out looking
I find not to much speed difference at all with it set high, Max bounces has more speed differences. Like 3 is faster than 1000, but I can't see much visual difference bewteen 5 and 1000....
by Kram1032 » Tue Aug 07, 2007 10:18 am
I usually use 10000 xD
Users browsing this forum: Ahrefs [Bot], tarikb and 52 guests
