Laubwerk Threes Support ?
Hi guys.
Well, as subject says...Is there any chance of getting this plugin working with Indigo? This plugin is already supported by Vray ( Max and SketchUp ) and Thea Render ( Max and SketchUp). I think It would be really awesome to have it also by our side
Not sure how crazy this can be ...however, is just a though
Cheers
http://www.laubwerk.com
Cheers
Re: Laubwerk Threes Support ?
I only recently purchased INDIGO and am learning it as best I can at the moment.
I own other renderers mentioned here generally, and have used LAUBWERK entourage with them, but in Indigo both the light (sun & sky, and HDRI's) and how it 'engages' with materials makes Indigo's renderingss simply the most beautiful, the most authentic to look at.
As such, I highly encourage Glare provide us a functional link between Indigo and Laubwerk. Their entourage is superb---equally authentic.
Certainly, Indigo is by far, the world's best render engine ever created ! And i'm very glad you're enjoying to work with it.David Paul wrote: ↑Sun May 27, 2018 3:48 amIndigo both the light (sun & sky, and HDRI's) and how it 'engages' with materials makes Indigo's renderingss simply the most beautiful, the most authentic to look at.
Welcome to the community
Cheers.
Thank you Lal-0.
Saludos del Canada.
Saludos del Canada.
Hi Lal-O.
Laubwerk plugin works great from C4D, with all options. It must be just an exporter thing, I guess...
Hi yonosoy !
Thx for the reply.
Well , for sure there is something with the exporter , i am a SketchUp user ( Skindigo ) and this is what i get:
Thx for the reply.
Search "Render mode" inside the tree definition and set the value to "Complete geometry".
Seems that actually you are rendering the convex hull.
Hope this help.
Hope this help.
Thank you once again for the suggestion , but it seems that option is not available in the Laubwerk version for SketchUp. SU has a major problem by handling high poly models and for sure that is the reason why is not possible to show the full geometry of the models
Will see later how this ends
Regards
Regards
You don´t need to view the complete geometry, is only a render flag.
Is very strange that the option is not there, anywhere related with Laubwerk menus.
This made the plugin unusable... and is hard to understand.
Good luck!
Sorry, now remember that you say that works with other renderers...
so don´t know
Good luck!
so don´t know
From their site: "Laubwerk Plants Kits come bundled with our Laubwerk Player, a plugin compatible with Autodesk 3ds Max, and MAXON Cinema 4D, Trimble SketchUp, and SideFX Houdini. Laubwerk SurfaceSPREAD is a Cinema 4D landscaping plugin".
Users browsing this forum: DotBot [Bot] and 46 guests
