Most up to date Indigo Exporter?
fourzeronine
Post by fourzeronine » Sun Sep 11, 2016 6:27 pm
I have a large animation project in Maya that I would like to render with Indigo 4 GPU. As we all know the Maya exporters are not being updated and have fallen quite far behind. I was hoping to alembic everything out to another software package to handle the indigo exporting. Which package has the most support for indigo (specifically 4)?
Re: Most up to date Indigo Exporter?
Post by Zom-B » Sun Sep 11, 2016 6:41 pm
DanJ
Post by DanJ » Mon Sep 12, 2016 7:59 am
Zom-B wrote:The c4d exporter by far: http://www.indigorenderer.com/forum/viewforum.php?f=10
What software would you recommend to learn, 3ds max or Cinema 4D?
Mainly from an ease of use perspective and support for indigo?
Main use would probably be product shots / architectural scenes
Thanks in advance
Post by Zom-B » Mon Sep 12, 2016 8:11 am
Just as I said, the c4d exporter is the feature richest and most bugfree exporter.
Its in development since years by the same guy (fused) from the dev team.
The 3D Max exporter is on development halt atm, but I should get some progress soon.
Anyway it will take quite some time until it gets as polished and "project proof", so you can work with it...
Originalplan®
Post by Originalplan® » Mon Sep 12, 2016 8:46 am
DanJ wrote:What software would you recommend to learn, 3ds max or Cinema 4D?
Cinema 4D :!:
Zom-B wrote:Just as I said, the c4d exporter is the feature richest and most bugfree exporter.
Yes, hats down to fused! Pro work on c4d front.
Post by Zom-B » Mon Sep 12, 2016 8:50 am
Post by Zom-B » Mon Sep 12, 2016 8:51 am
Originalplan® wrote:Yes, hats down to fused! Pro work on c4d front.
Well, I also do bughunting and testing of closed beta versions for C4D since many years :wink:
Originalplan®
Post by Originalplan® » Mon Sep 12, 2016 9:01 am
Zom-B you where the first one here EVER to help me with some c4d projects and problems of rendering.
It goes without saying that you are very well respected from Originalplan front. :wink:
Post by Zom-B » Mon Sep 12, 2016 10:25 am
Ha ha, thanks mate. My ego is back to max level again :P
fourzeronine
Post by fourzeronine » Mon Sep 12, 2016 7:12 pm
Thanks for the info. I guess I will have to start learning the c4d basics then. Hopefully alembic will do the trick. :)
contegufo
Post by contegufo » Mon Sep 12, 2016 7:41 pm
Hi
C4D and a good choice, and many users use the Indigo and may give suggestions.
http://help.maxon.net/us/#OSDS-ID_OBJECTPROPERTIES
DanJ
Post by DanJ » Mon Sep 12, 2016 8:04 pm
Thanks for info too. I'll start learning C4D then I think. Though it will take me a while as I will be fitting it in to my free time!
Post by Zom-B » Mon Sep 12, 2016 8:34 pm
Hey DanJ,
as a shortcut you can skip C4Ds Material System, since Indigo has his own materials inside of C4D.
Alembic features just had been updated in the recent R18 release, otherwise also try FBX.
If I understand correctly you rather need to learn setting up a Indigo scene in C4D then C4D by it self (for the start)
Here you can find some tutorials that help: http://www.indigorenderer.com/documenta ... -cinema-4d
DanJ
Post by DanJ » Mon Sep 12, 2016 9:06 pm
Zom-B wrote:Hey DanJ,
Thank you, I would also need to learn how to model too. I'll see what tutorials there are online for modelling and work my way through them, time and lots of practice are needed I think!
Originalplan®
Post by Originalplan® » Mon Sep 12, 2016 10:19 pm
Zom-B wrote:Ha ha, thanks mate. My ego is back to max level again :P
Good, that was the plan. :)
