How To Hyper Thread render
6 posts • Page 1 of 1
† Large †
Post by † Large † » Fri Feb 09, 2007 1:22 am
Hey yall... I'd like to know how to hyper thread render... You supose to add a -t in your xml file right..... But where are you supose to put it?? Cud some1 post up an example code showing how and where to place the -t.
Thanks
ryjo
Post by ryjo » Fri Feb 09, 2007 1:32 am
The '-t' should go on the command line, like this:
indigo.exe -t 2 scene.xml
... where 'scene.xml' is the scene to render.
You can also change the default setting in infile.txt:
"num_threads" "2"
† Large †
Post by † Large † » Fri Feb 09, 2007 1:33 am
oh my bad... i thought ur supose to add -t in the xml file... haha.. i must have miss read the topic about that...
Thanks ryjo
Kachu
Post by Kachu » Fri Feb 09, 2007 6:46 am
you also can edit the 'inifile.txt' file where it says
"num_threads" "1"
to "num_threads" "2"
My experience with my 2.4 Prescott HT was that using dual threads wasn't very useful (+5-10% Mutations per second, but Deathly killed other processes). My new C2D is a very different animal :D (+90-100% M.P.S., Hampering computer use)
Everyone else is doing it so : Core 2 duo E6600, 2 gb ram, Nvidia 8800 640 GTS and 250 gb hd
ryjo
Post by ryjo » Fri Feb 09, 2007 7:08 am
A good way to start indigo is to use
start /belownormal indigo.exe -t 2 scene.xml
This works on Win XP. It will put the indigo process in a lower scheduling class ("below normal") so the pc doesn't run so slowly for other processes.
boweeb007
Post by boweeb007 » Fri Feb 09, 2007 7:11 am
Prescott cores haven't always been dual core. Also, hyper threading itself doesn't mean dual core - it provides two logical cores. Though, if you have a dual core with hyper-threading, you could use 4 threads!
That might explain the performance difference.
Users browsing this forum: DotBot [Bot] and 1 guest
