Orthographic camera tests
Re: Orthographic camera tests
Ortographic camera and section cuts are WONDERFUL TOOLS!
Can't wait to test them!
Did someone request a telecentric lens anywayOnoSendai wrote:Hi CTZn,
As Etienne told me once, there is such a thing as a real orthographic lens, which does have a focal plane and focus blur - a telecentric lens:
http://www.edmundoptics.com/learning-an ... ne-vision/
edit: However, I have implemented the orthographic camera in Indigo as you described, as opposed to a telecentric lens.
Frankly I've been naive enough to believe that those two features would never be for Indigo and yet you did them !
While you are playing with cameras, why don't you consider to add clip-planes?
I need them for interior rendering of small rooms (european apartment are not so big
With current Indigo is impossible to render small bathroom.... (try to render a 2.5x2 mt room with daylight and without using fisheye camera
E.g. Try to render this image without removing the ceiling (if you remove the ceiling the "light response" changes = the light escapes from above)
The only way to render a bathroom like this (without using insane camera angle) is to use clipplanes or, better, to create a "virtual wall" (e.g. a wall invisible to camera but reflective to light). In 20-years old PovRay was possible...
- PureSpider
OnoSendai wrote:This and section planes will be in the next 3.4.x builds pretty soon!
There is a third one : a telecentric camdelle wrote: The only way to render a bathroom like this (without using insane camera angle) is to use clipplanes or, better, to create a "virtual wall" (e.g. a wall invisible to camera but reflective to light). In 20-years old PovRay was possible...![]()
Thechnically, this would be however very expensive to build, as you need a huge lens (a few meters for the bathroom), this is why these lenses are only made for shooting small objects. But you can take pictures with perspective virtually at infinity, and physically very close from the objects.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
It does sound like a real orthographic lens (given an ideal setup); as such, it requires one wall to be removed. Section planes are quite a tour de force.galinette wrote:Thechnically, this would be however very expensive to build, as you need a huge lens (a few meters for the bathroom), this is why these lenses are only made for shooting small objects. But you can take pictures with perspective virtually at infinity, and physically very close from the objects.
No! Not requiredCTZn wrote:it requires one wall to be removed
Ah I got it ! The rays are conducted from the eye through a rather small lens in the wall, toward a larger one putting the rays parallel.
Or the other way around
