Using .ply models
5 posts • Page 1 of 1
Maluminas
Using .ply models
Post by Maluminas » Fri Jan 26, 2007 12:38 pm
The .ply models from Stanford scans are too heavy for my computer to handle in Blender, and the decimated versions that came with the file are a mess (loss of detail, random double faces, holes, etc.). I think i read somewhere in here that you can 'append' a .ply model to the scene xml just like a .3ds model. I wanted to know how i could do this (if its possible lol), a code example would be perfect.
And in fact i cant even use the decimated files, because if i finally succeed at exporting it, the xml is so large that my computed hardly loads it and i cant add characters in the code unless i delete an equal number elsewhere in the text, which is really mysterious and annoying lol.
Thanks for any help :D
manitwo
Post by manitwo » Fri Jan 26, 2007 1:34 pm
	<mesh>
		<name>PLY-Model</name>
		<scale>1</scale>
		<normal_smoothing>true</normal_smoothing>
		<external>
			<path>models\model.ply</path>
		</external>
	</mesh>
:wink:
domparis
Post by domparis » Fri Jan 26, 2007 1:38 pm
<mesh>
	<name>big_mesh</name>
	<external>
		<path>path\to\model.ply</path>
	</external>
</mesh>
Same as 3ds append, be sure to introduce the "normal_smoothing" tag in the mesh block not in the model anymore.
For big ply object i have found in the forum a link to MeshLab, a very fast and efficient tools that clean, reduce very well polygons (quadric edge collapse fonction is aswome)
http://meshlab.sourceforge.net/
Hope it help
Dom
Edit : To late ;)
Maluminas
Post by Maluminas » Fri Jan 26, 2007 1:46 pm
Thanks! ill try all of that :)
Post by Zom-B » Fri Jan 26, 2007 8:03 pm
wow... totally new to me :shock:
I allways reduced ply models to a 65535 triangle 3DS file to use them in Indigo *lol*
nice to know, that I don't have to do that :wink:
**EDIT**
Works perfect! just one questions:
How do I rotate the model by using XML code??
Users browsing this forum: Yandex [Bot] and 22 guests
