MLT Sampling Method
6 posts • Page 1 of 1
ieatfish
MLT Sampling Method
Post by ieatfish » Tue Sep 20, 2011 10:04 am
If I start two renders and let them run for exactly the same amount of time, will they be the exact same image in the end? Or is the sampling random and I will instead end up with equally resolved images but not exact copies?
I ask because I am finding that (probably due to my poor lighting technique) I have some pretty grainy areas even after quite a bit of render time and was thinking perhaps I could blend two renders to get a more clear render.
Intel Core-i7 @ 4.0 GHz | GTX 580 | 12 GB RAM
Re: MLT Sampling Method
Post by PureSpider » Tue Sep 20, 2011 10:07 am
It depends on if you use the same random seed.
If you use the same seed, both images will eventually be the same, if you use different seeds, they will be different even after the same rendering time.
ieatfish
Post by ieatfish » Tue Sep 20, 2011 10:09 am
PureSpider wrote:It depends on if you use the same random seed.
Where does one set the seed?
Post by PureSpider » Tue Sep 20, 2011 10:10 am
You need to start Indigo (either GUI or CLI) from the command line with the -seed parameter set to some number.
indigo.exe -seed 12345
for example
galinette
Post by galinette » Tue Sep 20, 2011 10:51 am
More simply, if you do not bother with the seed, and if your number of threads is the same (because threads use different seeds), at same spp, images will be identical
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Meelis
Post by Meelis » Thu Sep 22, 2011 3:09 am
If you have grainy areas then you are not even close to final image.
In that case different methods have resolved image to different stage.
