Problem with grass.
6 posts • Page 1 of 1
yamh
Problem with grass.
Post by yamh » Sat Sep 17, 2011 9:02 am
hi guys im new using indigo ..so im trying to do some realistic grass...but i cant... i downloaded from the database the grass material : this are my settings
bump:::External:::::0.03
displacement:::external:::::0.12
here is the result Image
Uploaded with ImageShack.us
the grass area size is : 3 meter x 3.5 meters ..in case it matters...sorry for my english by the way!!
Re: Problem with grass.
Post by Borgleader » Sat Sep 17, 2011 9:18 am
There is more than one grass material in the databse would you be so kind as to link us to which one you used? Also, what does your mesh/uvs look like?
yamh
Post by yamh » Sat Sep 17, 2011 9:39 am
the number 4 in the vegetation database....
yamh
Post by yamh » Sat Sep 17, 2011 9:40 am
and mesh and uvs???? i dont know anything about that
Bosseye
Post by Bosseye » Tue Sep 20, 2011 2:26 am
yamh wrote:hi guys im new using indigo ..so im trying to do some realistic grass...but i cant... i downloaded from the database the grass material : this are my settings
That looks like just a flat texture on a flat plane given a bump map - hence the 'wavelike' quality to it.
If you're using sketchup a much better way to create realistic grass is to download the fur plugin from Sketchucation, then apply one of the grass textures from the Indigo website to a flat plane. Trim the plane to suit the grass size, make it a component and then use the mesh plugin to scatter the component around where you want your grass. Voila, better grass :) see below link:
http://www.indigorenderer.com/forum/vie ... start=2625
Post by CTZn » Tue Sep 20, 2011 4:47 am
Given the technique you wanted to use, yamh, the mesh should be given more subdivisions in order to reflect the texture features.
Right-click on the plane, SkIndigo > Edit Object then in the popping window set Max Subdivisions a little higher. Beware, do not use values above 3 if you are not sure what you are doing since each level multiplies the RAM consumption for meshes by 4.
Users browsing this forum: Majestic-12 [Bot] and 3 guests
