Exit Portals
Exit Portals
Hi all
This image have been rendering on one master and two nodes for seven hours so i thought i`ll try out Exit Portals. But the details around Exit Portals are a bit vauge. What makes an object and exit portal? Is it both an boject with s special kind of material? Does it have to be a 2D plane or can it be a 3D box as well (i am using Revit so creating a 2D plane is a bit of a hassel)
BIM Doctor
BIM Doctor
Re: Exit Portals
Depending on the exporter you are using, an exit portal is either a mesh with a special definition or with a special material, both are possible.
The standing point with exit portals is that light will flow in the direction of its normals, so using a closed cube would defeat the point: but, you can delete one face of a cube and flatten it some bits so the thin faces are around the exterior borders of your window, entering the wall a little to avoid leaks.
Don't forget to reverse the normals directions of that cube then. I can not guarantee that the lighting is strictly identical in both cases, planar EP's are to be prefered I believe.
You should also know that PT (GPU accelerated or not) has currently troubles to evaluate direct lighting through portals, these should not be used together if direct lighting is expected (use bidirectional PT and/or MLT).
Also try to find a more subtle bump value for the ceiling's bump as extreme values will spread the light more and amplify noise. It's better to set bump starting with low values.
Re: Exit Portals
Thanks
But what parameter of a material makes it an EP?
Re: Exit Portals
To be honest I don't know that, it's not documented and the Maya exporter is using the other solution (by mesh definition). It's only recently that I stumbled accross such a material definition, I can't remember where that was...
fused could tell for sure.
Exit Portals
Blendigo 2.6.1 still used a matrial definition to export exit portals. In the new Blendigo 3.0.10 for blender 2.5 it is a mesh parameter. Not sure that is the same for the new blending for Blender 2.49.
ATI Radeon HD 5750M 1024 MB
OS X 10.10.3 Yosemite
Re: Exit Portals
So how do we get the attention of fused?CTZn wrote:To be honest I don't know that, it's not documented and the Maya exporter is using the other solution (by mesh definition). It's only recently that I stumbled accross such a material definition, I can't remember where that was...
Re: Exit Portals
Most probably by posting in the Indigo for Revit forum, provided that he missed this threadBIMDAK wrote:So how do we get the attention of fused?CTZn wrote:To be honest I don't know that, it's not documented and the Maya exporter is using the other solution (by mesh definition). It's only recently that I stumbled accross such a material definition, I can't remember where that was...
Re: Exit Portals
You have my attention
Currently exit portals are not possible with Revit.
I don't know how possible it is to create 2D planes in Revit and also if one could change the normal direction of said plane (for exit portals normals have to point inwards), but I will look into how to make exit portals available in Indigo for Revit.
