Blender 2.5 Alpha 0 -- Released--
remus
Re: Blender 2.5 Alpha 0 -- Released--
Post by remus » Fri Nov 27, 2009 9:15 pm
Neo0, theres 3 little buttons at the bottom of the viewport that let you switch between face/edge/vertex selection. Alternatively ctrl+tab+2 will get you in to edge selection as well.
dougal2
Post by dougal2 » Fri Nov 27, 2009 9:33 pm
The existing Blendigo won't and never will work with 2.5 - you'll have to wait until we get some new code released.
don't panic, we're working on it 8)
Doug Armand
Post by Doug Armand » Fri Nov 27, 2009 9:53 pm
dougal2 wrote:The existing Blendigo won't and never will work with 2.5 - you'll have to wait until we get some new code released.
Thanks for the definitive answer - means I can stop wasting my time with it for the moment :D
Doug
Doug Armand
Post by zeitmeister » Sat Nov 28, 2009 3:10 am
Oh dear...
baking in blender should and must really be multithreaded. I can't make any use of my eight cores... it's a real pity.
Does anyone know why the boys don't work on that?
Post by Borgleader » Sat Nov 28, 2009 4:01 am
Oh yes I forgot to mention that earlier, the only reason the examples I linked to on the BA forums work is because theyve been built with the new python API, anything prior to 2.5 wont work.
Post by neo0. » Sat Nov 28, 2009 5:06 pm
remus wrote:Neo0, theres 3 little buttons at the bottom of the viewport that let you switch between face/edge/vertex selection. Alternatively ctrl+tab+2 will get you in to edge selection as well.
Oh there they are... I had to switch to edit mode.. Thanks!
Post by Borgleader » Sat Nov 28, 2009 6:32 pm
A lot of the buttons/menus are context sensitive now, which means they wont randomly still be there when they dont apply.
The best example of this is in 2.49 when you select a lamp object you still have the "Editing Tab" which normally contains mesh functions like subdivide, remove doubles, ... However on a lamp object this tab is empty yet still present and therefore useless. Notice how in 2.5 due to much more context sensitive-ness ;) when you select a lamp object the "materials", "modifiers" and "particle" tabs disappear and the icon for the "object data" tab changes to reflect the change in context.
Godzilla
Post by Godzilla » Thu Dec 03, 2009 2:43 pm
Aw.. :x
After a few computer troubles, I figured out I needed to install 2.5 (can't use any of the prior versions), and now I learn Indigo doesn't work with 2.5.. :(
Don't mean to be impatient, but any estimates on when the 2.5-compatible script will be up and running? :)
samlavoie.xyz
dakiru
Post by dakiru » Thu Dec 03, 2009 2:53 pm
Aw.. :x
I am curious :) why are you not able to use prior to 2.5 version?
Post by pixie » Thu Dec 03, 2009 10:11 pm
Godzilla wrote:After a few computer troubles, I figured out I needed to install 2.5 (can't use any of the prior versions), and now I learn Indigo doesn't work with 2.5.. :(
You're young, you've got time! :mrgreen:
Post by neo0. » Sat Dec 05, 2009 5:35 pm
So I've never really used blender before and I was wondering about something.. A lot of the time, Im going for a messy look, with objects scattered around my scene, as if someone dumped them there. Can blender's physics tools be used to arrange objects as well?
Post by Borgleader » Sun Dec 13, 2009 12:01 pm
http://www.blendercookie.com/2009/12/12 ... ender-2-5/
Holiday themed tutorial in blender 2.5 alpha0
dmn
Post by dmn » Sun Dec 13, 2009 7:34 pm
Will 1.1.18 users have to stick with 2.49, or is a rewrite intended for that as well?
Godzilla
Post by Godzilla » Mon Dec 14, 2009 12:45 am
dmn wrote:Will 1.1.18 users have to stick with 2.49, or is a rewrite intended for that as well?
I doubt it.
samlavoie.xyz
Jambert
Post by Jambert » Mon Dec 14, 2009 11:46 pm
Borgleader wrote:http://www.blendercookie.com/2009/12/12 ... ender-2-5/
thx for it, realy interesting :)
