This is the render of a study I'm making regarding a custom cluster I plan building.
Each node is a micro atx board with onboard gfx. Each row has only a slot where up to 3 hard drives can be hosted, and in one of these larger slots will host the router, the rest are diskless nodes (aand even those slots might start their lifes as diskless nodes).
They will be 24 per cluster at most, and limited to two clusters distributed alternately, at least until I study if the refrigeration is enough or not.
Ponderosa Wannabe
- pixie
Ponderosa Wannabe
- Ponderosa Wannabe
- im1215976894.png (377.16 KiB) Viewed 5525 times
