[SOLVED] MASSIVE problem with KDE
cheese on toast2
Post by cheese on toast2 » Fri Apr 18, 2008 4:52 am
hi everyone
ive got a huge problem with KDE in mandriva 2008. KDE has given up. when i try to log in, it says ' problem detected while trying to load KDE, tmp run out of space' then it says could not start kmserver, check your installation' then goes back to logon screen
what do i do???
any replies much appreciated!
dougal2
Post by dougal2 » Fri Apr 18, 2008 5:10 am
check your free disk space ?
cheese on toast2
Post by cheese on toast2 » Fri Apr 18, 2008 5:14 am
how do i do that? and if there isnt any, what do i do to free some up?
Post by OnoSendai » Fri Apr 18, 2008 5:18 am
df
cheese on toast2
Post by cheese on toast2 » Fri Apr 18, 2008 5:23 am
whats df?
Post by OnoSendai » Fri Apr 18, 2008 6:05 am
Type 'df' in a shell (command line)
Tells you the amount of disk free :)
cheese on toast2
Post by cheese on toast2 » Fri Apr 18, 2008 6:15 am
oh, i see. thanks :)
cheese on toast2
Post by cheese on toast2 » Fri Apr 18, 2008 6:42 am
ok, its official, the drive is full
typed df nd got
filesystem size used avail use%
/dev/sda5 5.1G 4.9G 0 100%
so i spose id better delete some stuff and/or resize my partitions, except i dont know how to delete stuff when i cant even log on and i dont know how to expand the mandriva partition from windows when the 'expand' option is blanked out :?
dougal2
Post by dougal2 » Fri Apr 18, 2008 6:55 am
well if you managed to get into a condole the following commands may help:
ls
show directory contents
ls -la
show directory contents, with details and hidden files
cd folder
chage directory to folder
cd ..
change folder up one level
cd ../../
change folder up 2 levels
(and so on)
cp file folder
copy a file to folder
mv file folder
move a file to folder
mv file1 file2
rename file1 to file2
rm file
delete file
first i would recommend that you
cd /tmp
into the temp folder,
ls
the files there to see if any junk is filling the disk
and
rm
any junk files.
dougal2
Post by dougal2 » Fri Apr 18, 2008 6:56 am
more info if you google something like "linux beginner commands"
eg.
http://www.reallylinux.com/docs/basic.shtml
cheese on toast2
Post by cheese on toast2 » Fri Apr 18, 2008 7:18 am
hmmm, tried cd/tmp and it says 'no such file or directory'. what am i doing wrong?
dougal2
Post by dougal2 » Fri Apr 18, 2008 8:00 am
put a space in between cd and /tmp
cheese on toast2
Post by cheese on toast2 » Fri Apr 18, 2008 8:49 am
lol ok, thanks
ok, deleted what i could in the tmp folder, and most of the stuff in my pictures too, but it hasnt made a difference. is there any other directory that might be clogging thigs up?
dougal2
Post by dougal2 » Fri Apr 18, 2008 9:26 am
I wouldn't like to say as I'm not at all familiar with Mandriva.
How much free space do you now have ?
Can you not move other large documents onto USB sticks or external HDs ?
cheese on toast2
Post by cheese on toast2 » Fri Apr 18, 2008 9:39 am
well, it says i still have 0GB free. also, i dont have a memory stick or an external HD. would moving to vista work? and if so, how would i go about doing that?
