h
yonosoy
Re: h
Post by yonosoy » Sun Sep 27, 2020 8:39 pm
"... the hamster don't see the wheel, and this wasn't said before." (yoS eidaN "el Olvidao")
https://www.instagram.com/yonosoy_nada/
schwungsau
Re: h
Post by schwungsau » Mon Sep 28, 2020 8:48 am
pretty cool,
what the render time on this anyway ? If I may ask
yonosoy
Re: h
Post by yonosoy » Mon Sep 28, 2020 10:27 am
Thanks.
58 min.
yonosoy
Re: h
Post by yonosoy » Sun Oct 11, 2020 9:34 am
Working in the big format...
Still some details to refine...
10 samples per pixel.
The displacement is wrong. The fact is that the gamma outs bad from photoshop, and the internal correction in Indigo don´t work as expected. Also the displacement needs exactly twice the value (please check this out! will try to offer you an example more over...).
Falling back. This one is correct, absolutely sure... 4K
yonosoy
Re: h
Post by yonosoy » Mon Oct 12, 2020 12:11 pm
ISL exercise, WIP.
Re: h
Post by OnoSendai » Mon Oct 12, 2020 1:17 pm
Love the cloud! I've been wanting to do a nice cloud reflected in the sea for forever.
wob
Re: h
Post by wob » Tue Oct 13, 2020 12:30 am
ISL exercise, WIP.
can you share the scene to learn your your technique? nice work
yonosoy
Re: h
Post by yonosoy » Fri Oct 16, 2020 4:20 am
Two meshes, two textures, a tree and ISL.
Investigating in this moments a normal shader for polygonal clouds.
Wob, will share more over some pieces of ISL. Once investigated...
The meshes comes from Houdini.
Don´t work as expected...
yonosoy
Re: h
Post by yonosoy » Fri Oct 16, 2020 10:34 pm
2h. Trying to focus with a wider aperture...
yonosoy
Re: h
Post by yonosoy » Tue Oct 20, 2020 12:06 am
13 h. Double diaphragm (too dark, developed with a contrast profile), an about f8 and about f64.
In sequence. As consequence, superfocus. Is focusing at 25 cm from the film (the cup of coffe in the first plane).
First signs of aperture diffraction... Some incongruity, must investigate.
yonosoy
Re: h
Post by yonosoy » Tue Oct 27, 2020 5:46 am
Some essays.
What happens in the maps? flipped... Now I see, is the second one... to investigate (thinking that is casual :))
yonosoy
Re: h
Post by yonosoy » Sun Nov 01, 2020 3:24 am
Contraformat horizontal (turned camera).
18 h. , atmospheric simulation, downsized 50 % .
