h
- schwungsau
Re: h
pretty cool,
what the render time on this anyway ? If I may ask
Re: h
Working in the big format...
Still some details to refine...
10 samples per pixel. The displacement is wrong. The fact is that the gamma outs bad from photoshop, and the internal correction in Indigo don´t work as expected. Also the displacement needs exactly twice the value (please check this out! will try to offer you an example more over...).
Falling back. This one is correct, absolutely sure... 4K
"... the hamster don't see the wheel, and this wasn't said before." (yoS eidaN "el Olvidao")
Re: h
Love the cloud! I've been wanting to do a nice cloud reflected in the sea for forever.
Re: h
Two meshes, two textures, a tree and ISL.
Investigating in this moments a normal shader for polygonal clouds.
Wob, will share more over some pieces of ISL. Once investigated...
The meshes comes from Houdini.
. Don´t work as expected...
Re: h
13 h. Double diaphragm (too dark, developed with a contrast profile), an about f8 and about f64.
In sequence. As consequence, superfocus. Is focusing at 25 cm from the film (the cup of coffe in the first plane).
First signs of aperture diffraction... Some incongruity, must investigate.
Re: h
Some essays.
What happens in the maps? flipped... Now I see, is the second one... to investigate (thinking that is casual
Re: h
Contraformat horizontal (turned camera).
18 h. , atmospheric simulation, downsized 50 % .
