h
yonosoy
Re: h
Post by yonosoy » Tue Jun 23, 2020 1:55 am
8.25 millions of instances.
Works well, thank you Ono!
Hello wob.
Here is an old example pigs by Ono that contains the scatter function.
Actually there is no possibbility of use inside Cinema. ATM only Skindigo has implemented the scatter function.
You must setup the scatters in XML. Noticed that the meshes to be scattered requires the "mesh UID" and the target object requires the "object UID".
scatter_material_test.pigs
(983.88 KiB) Downloaded 29 times
If Cindigo must write 8.25 millions of instances in the igs... you need hours of exportation. Indigo´s scatter put the instances directly in scene...
Hope that it will be implemented inside Cindigo someday.
"... the hamster don't see the wheel, and this wasn't said before." (yoS eidaN "el Olvidao")
https://www.instagram.com/yonosoy_nada/
wob
Re: h
Post by wob » Tue Jun 23, 2020 3:30 am
Hello Wob.
Here is an old example pigs that contains the satter function.
"You must setup the scatters in XML"
is this available for cinema 4d? can i use scatter with that xmls with cinema?
it's really great function, with full realisation in standalone app, why is it not added to cindigo gui yet? i tested your scene, it works fine
yonosoy
Re: h
Post by yonosoy » Tue Jun 23, 2020 4:29 am
Open the exported quickrender.igs in notepad. This is, XML (the text language of Indigo and many other programs).
So, the procedure:
1- Export the scene (with the objects to be scattered and the target object, as is).
2- Open the igs in a text editor.
3- Add this code at the end:
	<scatter>
		<uid>800000</uid>
		<name>the scatter</name>
		<shader>
				<shader><![CDATA[
def evalScale(int index) real :
  1.0
def evalCreate(int index, vec3 p) bool :
  true
						]]></shader>
		</shader>
		<proto_object_groups>
			<proto_object_group>
				<geometry_uid>8</geometry_uid>
				<materials>
					<material_uid>7</material_uid>
				</materials>
				<weight>1</weight>
			</proto_object_group>
		</proto_object_groups>
		<density>2</density>
		<seed>1</seed>
		<view_culling>true</view_culling>
		<orient_normal>false</orient_normal>
		<scale_std_dev>0.35</scale_std_dev>
		<height_std_dev>0.2</height_std_dev>
		<evenness>0.02</evenness>
		<z_offset>0</z_offset>
		<target_object_uid>25</target_object_uid>
	</scatter>
4- Change the geometry_uid and the material_uid to fit your object to be scattered (you can repeat a chain of code to scatter multiple objects).
geometry_uid > uid of the mesh in the file.
material_uid > uid of the material of the object.
5- Change the target_object_uid, use the uid of the model2 in the file.
6- setup parameters.
If you want to scatter more than one object looks like this:
				<materials>
				</materials>
				<weight>1</weight>
				<geometry_uid>12</geometry_uid>
				<materials>
					<material_uid>11</material_uid>
				</materials>
				<weight>1</weight>
If your object has more than one material:
				<materials>
					<material_uid>16</material_uid>
				</materials>
				<weight>1</weight>
Hope this help. :)
wob
Re: h
Post by wob » Tue Jun 23, 2020 7:22 am
So, the procedure:
	<scatter>
		<uid>800000</uid>
		<shader>
				<shader><![CDATA[
  1.0
  true
						]]></shader>
		</shader>
				<materials>
				</materials>
				<weight>1</weight>
		<seed>1</seed>
	</scatter>
				<materials>
				</materials>
				<weight>1</weight>
				<materials>
				</materials>
				<weight>1</weight>
				<materials>
				</materials>
				<weight>1</weight>
Hope this help. :)
thank you, i'll try, but it will not work with animation (multiple igs files) as i see, just if i'll make automation for including this text into every igs file in queue... perpahs, can i include this code into cinema 4d scene as indigo isl shader code or as any type of python script?
yonosoy
Re: h
Post by yonosoy » Thu Jun 25, 2020 6:41 am
The right procedure is to use several protogroups, one per object to be scattered (instructions corrected).
20 million. Scale of grass X2.
Corrections in 16 bit, without LUTs.
wob, wait for the update in the exporters for animations, it has been announced.
Ono, a bug with subdivision and scatters; more than 3 subdivisions produces this...
wob
Re: h
Post by wob » Fri Jun 26, 2020 8:21 am
wow. really impressive
yonosoy
Re: h
Post by yonosoy » Fri Jun 26, 2020 8:52 pm
Thank you!
Originalplan®
Re: h
Post by Originalplan® » Mon Jun 29, 2020 2:04 pm
Superb work Yonosoy!
yonosoy
Re: h
Post by yonosoy » Tue Jun 30, 2020 7:35 am
THANK YOU!
Re: h
Post by Oscar J » Tue Jun 30, 2020 8:52 am
Very cool!
yonosoy
Re: h
Post by yonosoy » Thu Jul 02, 2020 2:37 am
Thank you very much Oscar.
yonosoy
Re: h
Post by yonosoy » Thu Jul 02, 2020 7:25 am
Second attempt (not finished).
The metaphysical Body of the Father.
yonosoy
Re: h
Post by yonosoy » Thu Jul 02, 2020 8:33 pm
La herida (The wound). 2016.
yonosoy
Re: h
Post by yonosoy » Fri Jul 03, 2020 7:09 am
I don't want to finish it, I'll come back to it with the thirteen lenses in a days. Refining the job...
Four lenses at the Sun.
yonosoy
Re: h
Post by yonosoy » Tue Jul 14, 2020 9:05 pm
Technical stuff of v2...
v2.08...
Two hours. Accepts in blender a coating thickness of 1.375e-06 (only the first and the last lenses coated in this moments). Near to a perfect focus plane. Still working... :)
It is strictly functional (see blender capture).
