yonosoy
by yonosoy » Tue May 19, 2020 1:22 pm
yonosoy on Fri Jun 05, 2020 4:34 am, edited 3 times in total.
yonosoy
by yonosoy » Mon May 25, 2020 9:57 pm
yonosoy on Wed Nov 03, 2021 11:22 pm, edited 1 time in total.
by pixie » Tue May 26, 2020 4:52 am
yonosoy wrote: ↑Mon May 25, 2020 9:57 pm
Engel 02.
wow! \o/
yonosoy
by yonosoy » Wed May 27, 2020 1:00 pm
All this wave fields...
Thank you!
yonosoy
by yonosoy » Fri May 29, 2020 6:40 am
2 mm diameter is not enough for the first light plane. If the diaphragm is opened, the focus is lost (more over, with other cams).
With the modeled coating, the light pass through 52 mediums only for the cam...
And stop by the moment...
yonosoy
by yonosoy » Wed Jun 10, 2020 11:49 am
yonosoy on Wed Oct 27, 2021 9:50 am, edited 1 time in total.
yonosoy
by yonosoy » Sun Jun 14, 2020 7:40 am
yonosoy on Wed Oct 27, 2021 9:51 am, edited 1 time in total.
yonosoy
by yonosoy » Wed Jun 17, 2020 1:44 am
Online
by OnoSendai » Wed Jun 17, 2020 3:09 am
Looks good, is that with the updated sky model? (e.g. with latest Indigo release)
yonosoy
by yonosoy » Wed Jun 17, 2020 3:24 am
Yes, it is.
Only a subtle S curve as postproduction. Linear tonemapped EXR.
yonosoy
by yonosoy » Sun Jun 21, 2020 4:24 am
41.5 millions of instances.
Awaiting for slope (and others) possibilities with the scatter... with patience.
Online
by OnoSendai » Mon Jun 22, 2020 12:18 am
Ok, adding,
This is a test with the following shader:
def evalCreate(int index, vec3 p) bool :
normalWS(env).z > 0.8
p.s. excuse me for posting such an ugly image in your thread of beautiful images
(feel free to remove)
wob
by wob » Mon Jun 22, 2020 3:45 am
yonosoy wrote: ↑Sun Jun 21, 2020 4:24 am
is it indigo rendering result? 41 mln of instances??? how?
indigo seams going into a deepest trance while cinema 4d igs exporting with only 1 mln multi-instances scene - screenshot 1,
with huge memory leaks, screenshot 2.
just add simle cinema 4d scene to try...
Online
by OnoSendai » Mon Jun 22, 2020 4:16 am
wob: this is using Indigo scattering, which creates the instances in Indigo itself.
This tends to be a lot faster and use less memory, since it avoids the export process, doesn't try and render previews in C4d, etc..
wob
by wob » Mon Jun 22, 2020 9:15 am
OnoSendai wrote: ↑Mon Jun 22, 2020 4:16 am
i know how it works (redshift proxy), but can i use it in cinema 4d in cindigo or it's available only in standalone app? and where is this function avaliable, in which menu?
and why cinema 4d multi-instances dont work like that scattering?
Users browsing this forum: No registered users and 121 guests
