Page 1 of 1
[REQ] OBJ support
Posted: Fri Nov 17, 2006 8:32 pm
by CTZn
Allowing Indigo to use .obj meshes directly as it does with .3ds files would be much more than an upgrade for Maya/modo/ScketchUp/so on/... users.
Conversion between obj and 3ds is not an option, it has never, ever been in fact :roll:
Please...
Posted: Sun Nov 19, 2006 5:11 am
by MattMR2
Yes I agree with you.
if indigo can read obj as 3ds files that can speed up the export from maya with the maya script export (great stuff this exporter). also the exporter can only make the structures of the scene and link the obj file as a 3ds file... that will be say that the exporter for maya will be faster, more flexible and also can manage bigger scene without wait 30 min :shock: for export a scene (ps : I have a dual xeon HT 2.8 Ghz.... :roll: )
Do you think you can do this OnoSendai ?
Ps : shaders are great idea for layered material, is it possible to tell me how you do your 2 tests to mix 2 materials and is it possible with indigo v 0.6 ?
Best regards.
Matt
Posted: Sun Nov 19, 2006 5:12 am
by ThatDude33
yeah... if we can get a working obj import then I can make the exporter to actually work at normal speed :? ... rather than how slow it really is :(
Posted: Sun Nov 19, 2006 5:14 am
by psor
Yes, OBJ support would be great! :D :D :D
take care
psor
Posted: Sun Nov 19, 2006 5:53 am
by MattMR2
There are an obj exporter that works good in maya... if indigo can read obj, your exporter just need to export per object an obj file... that will be a great speedup... your exporter is slow but it exist so your exporter is an hope for maya user :wink:
Best regards
Matt
Posted: Sun Nov 19, 2006 6:00 am
by arneoog
OBJ! OBJ! OBJ! :D
Nick said it should work... indigo accepts them, but there is no object there when it renders... :?
Go, Maya-MEL-obj-XML-indigo syncing! 8)
Posted: Thu Nov 23, 2006 12:19 pm
by CTZn
Last but not least:
3DS File Format Toolkit
This archive contains the 3DS file format SDK. Note that the 3DS file format is no longer supported by Autodesk.
http://usa.autodesk.com/adsk/servlet/it ... id=7481394
:D
Posted: Sat Dec 02, 2006 6:23 pm
by CTZn
Arne wrote:Nick said it should work...
Well, using IndigoExplorer you can see that works
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<IndigoScene>
<Environment mode="1" color="255,255,255" turbidity="2" sky_gain="0.005" sundir="-57,-20,80" sundirHP="53,251" env_enabled="0" env_file_path="" env_width="640" env_gain="0.9" />
<Films selected="0">
<Film type="Camera" aspect_ratio="1.33" sensor_width="0.036" aperture_radius="0.001" white_balance="3" fps="25" xRes="800" yRes="400" regionType="0" region="0,0,0,0" split="0,0">
<Camera position="40.85987,16.2275,45.49464" rotation="-0.01335365,0.3799465,0.005485669,0.9248958" focus_distance="60.2105293273926" lens_sensor_dist="0.03" />
</Film>
</Films>
<Object path="C:/work/3d/simplet_man.obj" assemblyMode="2" layerHidden="">
<Material layer="Default" name="glass" />
</Object>
<Target outputImagePath="" />
<Render old_render_support="0" max_time="500" max_mutation_per_pixel="500" num_threads="1" bidirectional="1" image_save_period="20" save_tonemapped_exr="0" save_untonemapped_exr="0" metropolis="1" large_mutation_prob="0.4" max_change="0.025" max_num_consec_rejections="100" russian_roulette_live_prob="0.7" max_depth="1000" strata_width="5" logging="1" cache_trees="0" reinhard_pre_scale="1" reinhard_post_scale="1" />
</IndigoScene>
Indigo 0.6 rendered my object correctly ! Funky I would say... reverse slashes or something ?
Posted: Mon Dec 18, 2006 11:13 pm
by CTZn
Nevermind the previous post, this is not an Indigo description scene exposed here. I'm now pretty sure the issue with obj files is a material one :?
