Page 1 of 1
Noise
Posted: Fri Oct 23, 2009 2:04 pm
by kaneyeo
Hi
I am new in Indigo Renderer and I am evaluating this software for my company now.
Indigo Renderer generates very good photorealistic rendering from my SketchUp Model however I still cannot figure out reduce noise level after rendering for 13 hours. Have I missed any setting? or?
kaneyeo
Re: Noise
Posted: Fri Oct 23, 2009 4:43 pm
by benn
Hi kaneyeo,
Try setting your glass to 'Thin glass' using the Material Type chooser in SkIndigo materials. That will reduce fireflies.
Regards,
Ben
Re: Noise
Posted: Fri Oct 23, 2009 4:57 pm
by CTZn
Also you want to make sure that you are using exit portals for interior scenes, lit by (any type of) environment lighting.
Set colours to 80% value maximum, never 100% ! The same thing applies for colours saturation, it is better low.
Welcome !
Re: Noise
Posted: Fri Oct 23, 2009 5:57 pm
by kaneyeo
Thanks Ben, I have removed all glass objects and I still gets same amount of fireflies
benn wrote:Hi kaneyeo,
Regards,
Ben
Re: Noise
Posted: Fri Oct 23, 2009 6:00 pm
by kaneyeo
Thanks CTZn, Any clues for exit portals? Like a print screen image to show me how or where to set?
CTZn wrote:Also you want to make sure that you are using exit portals for interior scenes, lit by (any type of) environment lighting.
Welcome !
Re: Noise
Posted: Fri Oct 23, 2009 8:35 pm
by Pibuz
"Exit portal" is just another kind of shader, you find it in the shader type drop-down list in the SkIndigo mat editor. Just apply a simple colour to a surface (make sure that is the white SU face), place it to cover the holes in the walls (your windows
) facing inside your room and choose "exit portal" as the shader. Done.
That won't reduce your fireflies, I fear. I often see similar effect when using metals: make sure your metallic objects are detached from the base surface by 1mm. That should help reducing your fireflies.
Re: Noise
Posted: Sat Oct 24, 2009 5:16 pm
by benn
Hmm strange scene bug - could you send us the .skp file?
ben@indigorenderer.com. You can also try using metroplis light transport (MLT) to reduce fireflies - or decrease the MNCR number (in skindigo advanced settings).
Re: Noise
Posted: Mon Oct 26, 2009 2:59 pm
by kaneyeo
Thanks Pibuz, for your "Exit portal" information. As for my rendering, I have just left all windows empty for daylight comes into interior without "Exit portal" shader. I did another test on my model by rendered over weekend with and without ceiling. The one without ceiling has very litte fireflies while the one with ceiling still have them after 65 hours of rendering...
Pibuz wrote:"Exit portal" is just another kind of shader, you find it in the shader type drop-down list in the SkIndigo mat editor. Just apply a simple colour to a surface (make sure that is the white SU face), place it to cover the holes in the walls (your windows
Re: Noise
Posted: Mon Oct 26, 2009 3:03 pm
by kaneyeo
Thanks Benn, I will send you skp file thru your email
benn wrote:Hmm strange scene bug - could you send us the .skp file?
Re: Noise
Posted: Mon Oct 26, 2009 4:36 pm
by Zom-B
Hey Kaneyo, please fololw
CTZn's guidelines about color!!!1!
Your white color is some real pain for every raytracer.. use max of 200,200,200 for RGB
Re: Noise
Posted: Mon Oct 26, 2009 6:59 pm
by kaneyeo
Thanks ZomB, I will give a try on setting my white to 200,200,200.
ZomB wrote:Hey Kaneyo, please fololw
Re: Noise
Posted: Mon Oct 26, 2009 7:19 pm
by Meelis
Hey
I'm interested about the pure white. What happens with that, because there is only 20% between 1-1-1 and 0.8-0.8-0.8 or ~50% less colour tones.
Re: Noise
Posted: Tue Oct 27, 2009 12:41 am
by psor
There is no 100% reflectance in the real world. The maximum measured reflectance is 88% and
that is a white glossy sheet of paper. If you set reflectance to 100% then the pathtracing will go
mad cause the rays will bounce like crazy will cause unexpected results as bad looking materials,
fireflies, washed out images and speed decreasing. So using pure white aka 255/1.0 should be on
top of the list of nono's. If you want things look real start to use real material settings.
btw. this is the case for all render engines.
Here a graph that shows the decreasing speed of the engine.
take care
psor
Re: Noise
Posted: Tue Oct 27, 2009 2:29 am
by Meelis
Very interesting. And that's really big speed difference.
