Violet for 2.0+...?
Violet for 2.0+...?
Any news if there is going to be another Violet update? it is a very useful program, and it would be nice if we could use it with 2.0+ versions.
samlavoie.xyz
Re: Violet for 2.0+...?
I'd love to see a new Violet too. With camera tonemapping. ;o))
I wrote the guys from qtpfsgui an mail and asked to support
the igi file format. No reply till now tho. I miss Violet! ;(
take care
psor
take care
psor
"The sleeper must awaken"
Yes, that would be awesome. Indigo can do that, btw... well sort of...
After you stop rendering it keeps the igi in memory so you can tonemap it. Maybe all that has to be done is to build some way in to load a igi without a scene?
The current Indigo GUI does interactive tonemapping just fine.
How does it simulate the effect bloom without violet?
iacx: Use aperture diffraction, it's much more realistic.
Thanks Ono !
Could you please add a "Open IGI" kinda entry to the menu, so we are able to tonemap theOnoSendai wrote:The current Indigo GUI does interactive tonemapping just fine.
image and play with the light groups later on. That would rock!
Thanks in advance.
take care
psor
Hi Psor, you can achieve the same effect by resuming the render. But yes, I will add that to the menu.
not everyone keeps igs files forever
That's true, non the less I keep them longer then I've Indigo open tho. ;o))fused wrote:not everyone keeps igs files forever
The difference might be, that I changed the .igs or deleted it. Thanks!OnoSendai wrote:Hi Psor, you can achieve the same effect by resuming the render.
take care
psor
interactive tonemapping relies on the IGS file because the aperture diffraction parameters are in the IGS file. So there will be a bit of work to get around this, but It can be done I guess.
Ohaa, I understand. I hope it's not to much work for you. It wasn't my intention to do so.
Then probably it's better to keep the .igs tho.
take care
psor
take care
psor
I would suggest to alter the .IGI file-format in way, that (something like) an EXIF header with all the relevant informations will be added to it.OnoSendai wrote:interactive tonemapping relies on the IGS file because the aperture diffraction parameters are in the IGS file. So there will be a bit of work to get around this, but It can be done I guess.
- pixie
+1Phoenix wrote:I would suggest to alter the .IGI file-format in way, that (something like) an EXIF header with all the relevant informations will be added to it.OnoSendai wrote:interactive tonemapping relies on the IGS file because the aperture diffraction parameters are in the IGS file. So there will be a bit of work to get around this, but It can be done I guess.
Users browsing this forum: No registered users and 93 guests
