Has anyone ever noticed that if saving of an .IGI is interrupted (Your computer freezes, Indigo freezes, whatever), if you resume the render, there is a line on the render? (Where everything below/above the line is much much darker than above/below the line)
Obviously caused by the Interrupted saving process, but it would be nice if there was a fix for this, because when I am rendering at high-resolutions, it isn't very uncommon for it to happen (And keep in mind my computer isn't exactly 'old' , so I'm sure i'm not the only one who is experiencing such events.)
Issues with .IGI's and auto-saving.
samlavoie.xyz
Re: Issues with .IGI's and auto-saving.
Interrupting the saving of any file will cause problems - kinda like asking to fix the problem of power going out when power lines get cut
And that sounds like a you only problem - ive never had that on any of my machines
Yes i know, my spelling sucks
- Borgleader
However, there may be a "fix" anyway. unlike power, igi saving is (as i understand it) simply the rewriting of the igi everytime the save period comes up right?eman7613 wrote:Interrupting the saving of any file will cause problems - kinda like asking to fix the problem of power going out when power lines get cut
it could be possible to make it a 2 (technically 3) stage process:
1. Write a temporary igi.
2. Ovewrite old igi (only if new igi is complete, theres probably an "end" tag in the file so look for that or something)
3. Check if new & old igi are the same (if so delete new igi)
rinse-repeat
Damn, that sux. Apparently MoveFileEx isn't atomic on Windows like I thought, although Vista onwards added an atomic file replace operation. So maybe I'll add atomic IGI update support for Vista onwards.
Exactly what I was thinking of... but was too lazy to type out.Borgleader wrote:However, there may be a "fix" anyway. unlike power, igi saving is (as i understand it) simply the rewriting of the igi everytime the save period comes up right?eman7613 wrote:Interrupting the saving of any file will cause problems - kinda like asking to fix the problem of power going out when power lines get cut
rinse-repeat
samlavoie.xyz
