easyarchitect
by easyarchitect » Wed Sep 09, 2009 9:18 pm
Hi, I was playing around a Velvet Shader in GLSL derived from the Velvet Renderman Shader written by Stephen H. Westin (see attached file "SHW_velvet.zip"),
maybe this can be used by Ono to add a Velvet like material to Indigo
P.S. I've attached the Paper written by Stephen H. Westin ("Stephen H. Westin.zip") and my GLSL Shader
Bye
GLSL Shader (Vertex):
varying vec4 Ca;
varying vec4 Cd;
varying vec4 Cs;
varying vec4 V_eye;
varying vec4 L_eye;
varying vec4 N_eye;
void main(void)
V_eye = gl_ModelViewMatrix * gl_Vertex;
L_eye = (gl_ModelViewMatrix * gl_LightSource[0].position) - V_eye;
N_eye = vec4(gl_NormalMatrix * gl_Normal, 1.0);
gl_Position = gl_ProjectionMatrix * V_eye;
V_eye = -V_eye;
Ca = gl_FrontMaterial.ambient;
Cd = gl_FrontMaterial.diffuse;
Cs = gl_FrontMaterial.specular;
GLSL Shader (Fragment):
varying vec4 Ca;
varying vec4 Cd;
varying vec4 Cs;
varying vec4 V_eye;
varying vec4 L_eye;
varying vec4 N_eye;
const float backscatter = 0.25;
const float edginess = 4.0;
const float sheen = 0.7;
const float roughness = 0.1;
void main(void)
vec3 V = normalize(vec3(V_eye));
vec3 L = -normalize(vec3(L_eye));
vec3 N = normalize(vec3(N_eye));
float diffuse = clamp(dot(L, N), 0.0, 1.0);
float cosine = clamp(dot(L, V), 0.0, 1.0);
float shiny = sheen * pow(cosine, 1/roughness) * backscatter;
cosine = clamp(dot(N, V), 0.0, 1.0);
float sine = sqrt(1.0 - cosine);
shiny = shiny + sheen * pow(sine, edginess) * diffuse;
gl_FragColor = Ca + (Cd*diffuse) + (Cs*shiny);
- Velvet Sample
- Velvet.PNG (64.11 KiB) Viewed 3973 times
- Stephen H. Westin.zip
- Stephen H. Westin Paper
- (891.98 KiB) Downloaded 240 times
- SHW_velvet.zip
- Renderman Velvet Shader
- (1.12 KiB) Downloaded 224 times
easyarchitect on Wed Sep 09, 2009 10:17 pm, edited 2 times in total.
by OnoSendai » Wed Sep 09, 2009 10:00 pm
Hi, I plan to do a bit of work on Indigo shader language (ISL) to allow for stuff like Velvet, thanks for the information!
easyarchitect
by easyarchitect » Wed Sep 09, 2009 10:08 pm
OnoSendai wrote:Hi, I plan to do a bit of work on Indigo shader language (ISL) to allow for stuff like Velvet, thanks for the information!
Hi Ono, I've modified the GLSL code in order to remove the "uniform" for Light's position..
Bye
by Zom-B » Wed Sep 09, 2009 10:55 pm
ISL updates are VERY welcome Ono
If they are also followed by some small tutorials just like
here its even more awesome!!!
easyarchitect
by easyarchitect » Wed Sep 09, 2009 11:28 pm
Sorry but I've found a bug into GLSL Shader, now should be fine...
GLSL Vertex Shader
varying vec4 Ca;
varying vec4 Cd;
varying vec4 Cs;
varying vec4 V_eye;
varying vec4 L_eye;
varying vec4 N_eye;
void main(void)
L_eye = gl_LightSource[0].position - V_eye;
V_eye = -V_eye;
GLSL Fragment Shader
varying vec4 Ca;
varying vec4 Cd;
varying vec4 Cs;
varying vec4 V_eye;
varying vec4 L_eye;
varying vec4 N_eye;
void main(void)
vec3 L = normalize(vec3(L_eye));
float diffuse = max(dot(L, N), 0.0);
float cosine = max(dot(L, V), 0.0);
float shiny = sheen * pow(cosine, 1.0 / roughness) * backscatter;
cosine = max(dot(N, V), 0.0);
- Testing GLSL Velvet Shader
- Test velvet.jpg (226.83 KiB) Viewed 3902 times
easyarchitect
by easyarchitect » Tue Sep 15, 2009 9:25 pm
Hi Ono, I've included this Shader into Povray, this is the result
When the ISL will permit these type of Shaders I'll try to port the Velvet Shader to Indigo
Bye
- Velvet sofa.jpg (292.39 KiB) Viewed 3831 times
easyarchitect
by easyarchitect » Tue Sep 15, 2009 9:29 pm
Here is the OpenGL Version (with Bump Mapping and Shadow Maps)
- Velvet OpenGL.jpg (291.8 KiB) Viewed 3828 times
easyarchitect
by easyarchitect » Wed Sep 16, 2009 2:36 am
Hi, I've created a video sequence (divx format) that shows the shader in action (frames rendered in OpenGL)
Please Ono....
Bye
- Velvet Sofa mpeg4.zip
- (4.3 MiB) Downloaded 218 times
